Results 1 to 6 of 6
- Jul 2010
- 35
February 12th, 2012 05:37 PM #1Hello guys,
How do you figure out my XTO with 135k mileage. I cannot rev it over 2k even if I floor the gas pedal.
I recently had a changed oil. On flat road it runs normally but when I climb a long streetch of road, it is very slow and stalls or dies. After a few minutes I can start her again.
Is it overheating? loose compression?
- Sep 2006
- 89
February 13th, 2012 03:34 PM #3
Automatic? If you have problems climbing, it may be that the box isn't downshifting. As there's enough torque to get going in second gear, it's not a problem on a flat road, but when climibing, it'll be obvious.
It could also be a problem with the fuel system. A clogged filter or element that is more affected in certain positions and at certain angles.
February 13th, 2012 08:10 PM #4
Pa check mo din sir sa calibration baka din sa delivery pump (injection pump)
- Jul 2010
- 35
February 14th, 2012 11:12 PM #5Got it right, Niky. The fuel filter and the water separator were half filled with mudlike sludge. After the replacement and cleaning in the fuel filter area, I could already rev up to 4k or redline. There was also less visible smoke as compared to before the replacement. I realized, the fuel filter had not been replaced for more than 3 years.
My auto tranny XTO now feels nimble and I feel the problem is solved already though I still have to test it in climbing.
I brought it to the calibration later but the mechanic told me that the engine was still good.
medyo disappointing itong Sealion 5 No ADAS No 360 camera
Yaris Cross 1.5 S HEV CVT vs BYD Sealion 6 DM-i
