Page 3 of 4 FirstFirst 1234 LastLast
Results 41 to 60 of 83
  1. FrankDrebin Guest
    Quote Originally Posted by jaydel View Post
    repair lang ang ginawa old shocks. wala sa budget ang bumili ng bago. 1,400 lang binayad ko para sa repair. Bumalik ulit ako yesterday para magpapalit ng stratbar sa Cruven. Ok na takbo ng sasakyan -- parang bago
    Mabilis bang masira ang strut bar ng Crosswind?
    Jun 2005
    San ba yang Cruven sir?
    Under warranty pa naman si Dayunyor kaya ok lang ako sa ngayon sa casa. But when the time comes, at least alam ko na kung san ako pupunta in cases like these.
    Feb 2005
    Quote Originally Posted by Psalm136:2
    Dude,
    You'll get all the information you need at their website. http://www.cruven.bravehost.com/
    Dami nga nagpapagawa kahit na bago kotse nila
    Enjoy!
    Aug 2005
    Hlo guys. ngayon lng ko reply kasi nakalimutan ko password ko.
    lam ko KYB din ung orig sa XTO but oil filled shocks daw. I replace mine with gas shocks. I guy told me na ok daw gas if heavy loading, di sya matagtag pag mabigat. ung oil filled naman di matagtag pag wala load but matagtag kung loaded. correct me guys if wrong ung Info.
    regarding the inverted leaf spring, ung kakilala ko pick-up ung pina invert nya. pero ung panakamaliit na leaf spring lng. so if apat ung leaf spring mo. isa lng naka-invert ung nasa bottom and smallest, the rest orig position. ok naman daw, and siguro kung isa lng di naman siguro madaling mabali un. pero di ko parin Muna gagawin. pinag-aaralan ko pa.
    Quote Originally Posted by Silverwrench
    xto oem shocks is gas already sa likod from kayaba (KYB)
    Yung leaf springs ng mga imported na right hand drive Suzuki pick-ups na convert dito
    left hand drive have inverted last leaf design, orig ito from Japan. There's a lot of these Suzuki's running around so it's easy to spot them.
    Kaya pala mas mahal ng utol ko yung Hilander SLX nya kesa yung XUV. Sarap ihataw yung SLX, car-like ride tsaka mabilis lalo na sa akyatan.
    May leak na 'yong left rear shocks ng XUVi ko, gusto ko ng palitan 'yong OEM shocks (KYB) into aftermarket... based sa mga saguta 'yong OME ang maganda... meron din 'yong sinasabing double action kaso 6.2k per piece (tama ba)?
    Isa pang option is the Gas-A-Just shock refill para sa shock.
    So which one is the best replacement shock? Otherwiese KYB na lang ulit bilhin ko for the replacement.
    Feb 2005
    tanong ko lang kung saan mura bumili ng leafsprings (new or surplus). Ang baba na kasi ng likod ng XTO ko. Parang umunat na yung leafsprings. I would really appreciate your help.
    Thanks.
    u try to call makati isuzu meron dati sila recomend na store sa may binondo area malapit lang sa kanto ng soler
    Have an 03 XUVI nung una para ngang matagtag, pero nung tumagal parang nasanay nako!! minsan nga pag dinadrive ko yung pjero ko hinahanap ng pwet ko yung tagtag ng crosswind ko eh!! Minsan nga pag nalulubak ako sa crosswind ko napapsigaw ako ng yooon machong macho. heheheeh. Si misis napapiling nalang.heheh
    Aug 2006
    hello,guys .bago lang ako dito at do ko pa din gaano nasusubukan ang XTO ko 2001 model sya automatic. kapapalit ko lang kasi from sedan.tsek ko na lang posts sa thread na ito pag naencounter ko same problems.
    Jan 2008
    Quote Originally Posted by dprox View Post
    About the Crosswind XUVi.
    Smooth ang ride so front, pero matagtag :jump: sa middle & rear.
    Can anyone suggest what to do to make the ride smoother?
    Are there substitutes/alternatives to the factory suspension? Conversion kits?
    Salamat
    Good day mga x-win owners,, alam nyo simple lang yon, no need to replace anything sa ilalim, experience ko sa L-3 Fb ko pag mababa ang pressure ng tires lalong matagtag yon pero pag naka 35psi ang tires ng L3 both rear/front ehh dyan ko na feel ang flex ride.
    I have my new sportivo last dec 2007, 26psi frnt 35psi rear company default, i tried 30psi frnt 40 rear, wow dyan mo ma feel ang flex ride, mas lalo ka kasing e-tagtag ng tire mo pag medyo malambot lahat ang tires nyu, yung suspension ang ipa work ninyu hindi ang tire pressure.. dapat medyo matigas yung tires para mag work ang suspensions ng x-winds, rty nyo
    Nov 2007
    Quote Originally Posted by mang_tasyo View Post
    ganun ba? i have a sportivo and based on my experience, mas matagtag xa pg mlaki ang hangin, say 37 psi sa likod, lalo na pg walang load kc mafefeel mo tlga ang tigas..
    Jun 2008
    Do the KYB Gas-A-Just shocks really make a difference sa smoothness ng ride?
    I own a 2003 Isuzu Crosswind XUV. Super tagtag sa likod. Current tire pressure is 30psi sa front and 34psi sa rear. I called Isuzu and they told me na 2005 up models lang daw ang may flex ride suspension at oil-filled shock absorbers pa ang nakalagay sa 2003 model. They also told me na hindi parin magiging smooth and ride ko kahit palitan ng gas-filled shocks, kahit monotube raw i.e. KYB Gas-A-Just kasi useless pag hindi palitan ang leafsprings ko. If the leafsprings are stiff, useless magswitch to gas-filled shocks.
    Is this true? Anyone who can confirm this?
    Thank you very much.
    Aug 2004
    Yeah, I've got Rancho 9000 (9-way) shocks, and it's very hard to dial the ride right.
    A proper suspension balance means that your tire pressure, spring stiffness and shock damping should all match perfectly... and since then don't match at all on the Crosswind as stock, getting them to approximately the right position is an exercise in futility.
    Reverse one spring, but leave in snubbers (or whatever the heck they're called) so that it still supports the extra weight when you're carrying heavy loads. But you'll need to upgrade shocks. The stock shocks suck, no two ways about it.
    A low tire pressure won't help, either. Too little pressure and it'll just accentuate the bounciness... I figure 30-32 should be just about right.
    Jun 2008
    Thanks for the insight niky.
    Are there any KYB dealers in Cebu na merong KYB Gas-A-Just shocks for a 2003 Crosswind?
    Old Man Emu shocks magkano kaya? Any dealers in Cebu?
    Sep 2009
    Quote Originally Posted by skidmarkharvey View Post
    Just got back from banawe, have an isuzu xuvi 2003, changed the rear shocks becuz the stock ones were leaking. Got the KYB gas shock absorbers (they cost me 1,400 each). Also got the rear lifted using hangers which cost me 1800 for both including labor. Just so i dont forget (and because no one here really puts up the price) changed my front tires at michelin the fort, they cost 5400 each. Changed my alarm din in banawe which cost 2000 (the stock alarm is loud, annoying and rattles my wife everytime i set it on). The only thing i think that helped with making the ride smoother was i had nitrogen placed in my tires instead of air at michelin. It costs 100 per tire and i can go back if ever the tire gets soft for free. There they recommended all tires at 30psi, and it myt be psychological but i feel there is a slight improvement. Got HIDs din na china lang, they cost me 5k for both, its been about 2 years na and so far so good.
    Jan 2011
    reviving this thread..
    guys, baka meron gustong magpost ng updates or modifications ng crosswind suspensions nyo jan?
    pictures sana kung meron.. :D
    Thanks!
    Sep 2010
    ahhh...I see...kaya pala bago ako bumili nung sportivo 2005 ko...yun ang madalas kong mabasa o madinig,about the bad suspension...pero nung magamit ko na yung sportivo 2005 model ko,kabaligtaran pala lahat....kasi napakasarap naman pala sa rough road...kaya yun,bumigay na din yung shocks ko...di ko naalagaan...sarap kasi parabasin sa batsi,hehe...madalas kasi ang byahe ng bicol-manila...kung minsan dyan sa parteng quezon province,grabe ang rough road...nakakainip naman magpabagal,kasi malayo pa ang byahe...
Crosswind Rear Suspension
