Results 1 to 6 of 6
    Is this normal for all dual a/c vehicles? i had vanette and galloper before and the same problem, mas malamig ang front kaysa rear. can anyone here confirm it with their crosswinds?
    Feb 2005
    Quote Originally Posted by ravelcop View Post
    vehicles you mentioned (including the Crosswind) only has one compressor but with 2 a/c blowers -- one in the front and the other one at the rear. Notice that there may be a BLOWER SWITCH at the rear but does not have an a/c thermostat unlike the front. Ergo, if you reduce the thermostat adjustment in front, the same occurs at the rear.
    Considering that the front a/c blower is nearer to the source (compressor), it is often noticed that the air temp in front is "colder" than of the rear.
    thanks Benzmizer, that makes sense. so the freon that passes the rear evap has already gone through the front evap that's why it's less cold
    Sep 2010
    thanks bro benzmizer...nuon ko pa din gusto itanong yan e....
    Feb 2014
    Quote Originally Posted by Benzmizer View Post
    aun.!! so normal lng po pla na hndi ganong malaming ang rear aircon ng mga xwind gnun dn po kc ung samin parang fan lng kc sya lalo na kpag tanghali pero ung front aircon malamig nmn.. pero kapag hndi nmn na ganong mainit mejo lumalamig na ung rear aircon.. akala ko may sira na yung rear aircon nmn kc hndi ganong malamig..
    Sep 2009
    ako pinapatay ko minsan dahil naninigas mga daliri ko sa lamig habang nagmamaneho. dusa naman sa init yung mga sa gitna at likod.
Crosswind front a/c is cooler than rear
