Hi tsikot gurus. I hope you could help me. I don't quite understand what's the problem with my crosswind's headlight. Details below:
Unit: 2001 crosswind XTO
Headlight problem:
1. It has very poor dim light. If there's a car behind, you would see your cars shadow even with your head light on. That's how poor the light is.
2. The bright doesn't work. Sometimes, it would work for like 1 or 2 seconds, and it will go off. But very much often, it doesn't work at all.
Other facts:
1. I just had my headlight bulb replaced last month. When I had the headlight checked this afternoon, one of the socket showed some burning signs, I had it replaced with a ceramic socket, still the problem exist. The bulb is 100/90 or 95 Watts. Which performs way lower than the original 60/55W as I see it.
2. The electrician who checked it this morning said that because we used a higher wattage bulb, and my crosswind doesn't have a relay, the switch board something may have been damaged. He said that we'd have to remove the steering wheel, and check the switch board tomorrow.
Any ideas guys? Thanks a lot.
benchao
This headlight issue started a few days ago.
