Page 1 of 2 12 LastLast
Results 1 to 20 of 24
    Apr 2009
    need help to all crosswind gurus, my handbrake light(kahit nakababa), water separator indicator light and my batery lights is on even my engine is on. di ko alam kung ano problema, ok naman sya kaninang morning and the problem is gabi na and im in my office. d ko sure if safe gamitin. need advice po.
    Feb 2005
    Quote Originally Posted by blyx21 View Post
    Looks like a bad ground to me.... Try checking your fuse too.
    Apr 2009
    Quote Originally Posted by Benzmizer View Post
    my sportivo is now ok, pinatakbo ko parin kahit umiilaw yung batt,water indicator and handbrake light. what happen is after 3mins of running nawala yung 3 ilaw. then i turn of the engine and start again the problem is gone. bakit kaya ganon, i mean what happen kaya?
    Feb 2005
    Hmmm, that's odd and unusual. fact that all 3 indicators simultaneously lit says it's not of the ordinary. Some guide questions:
    1. Di ka ba nalubak some point going to your office yesterday morning?
    2. Did you have any modifications on your car that is electrical related?
    Pending your reply to those questions, a part of me suspects either:
    1. Bad grounding (Check ground points)
    2. Loose connection (Check ground points/connections)
    Have a trusted/reputable electrician (best if CASA) check your electricals.
    Jul 2003
    Pacheck mo alternator mo kung kumarga or bibigay na ang mga diode.
    Apr 2009
    what i notice lang it happen when pag rainy days maybe, last time kc nagloko yung alarm ko, may nabasa ata sa loob, not sure lang kung anong yung nabasa
    Apr 2009
    Quote Originally Posted by nap123 View Post
    any ideas kung san ko pwede pa check aside sa isuzu casa, cubao area ako.
    Feb 2005
    Wizzard comes to mind.
    Apr 2009
    sir san banda po yung wizzard? can pm/post the address? daan ako tom. ty
    Apr 2009
    got the address na malapit lng pala sa dallas. ty
    Aug 2009
    bossing. we got the same problem.. mine is abs, handbrake and airbag. dalwang tech2scan sa isuzu CASA hanggang ngayon same problem parin.. i spent 800 to 1k for the tech2scan.. sayng ung pera. parang tinapon ko lang. hindi naayos sa CASA
    Apr 2010
    Ano kaya nga yong nababasa, dahil naranasan ko din yon sa sportivo. medyo mabilis ang takbo at may nabasa yata sa loob ng engine compartment pero nawala din agad.
    Apr 2009
    Quote Originally Posted by baby_scar View Post
    the problem resist parin so i plan to go to wizzard a while ago, pero badtrip biglang ayaw magstart sportivo ko, ginawa ko nagpalit ako ng new battery baka battery lang prob, pero sabi sa akin ng tech sa auto supply na baka alternator daw sira. nung pinalitan na ganon parin problem pero nagstart na siya. so pumunta ako sa wizzard sad to say di ako umabot sa pag gawa pero pinacheck ko sabi baka may problem nga sa alternator. so planning to go back to tom again, ask ko lang mura ba sa wizzard kaysa sa banawe? if pag sa banawe san kaya pwede pagawa? need advice po. sabi kc mahal raw alternator pag papalitan it will cost 10k+
    Jul 2003
    Bro Rey Electrical lang ang katapat niyan. Mura lang alternator ng crosswind syempre mahal yung CASA price.
    Apr 2009
    so you mean sir mas mahal parts kay wizzard?
    Feb 2005
    It surprises me that those who looked at your Sportivo seemed to be "guessing" what the cause of the problem. A seasoned and reputable electrician would easily know if it's the alternator, battery or wiring.
    For instance, a bad alternator can easily be detected by checking its charging rate. If found defective, he would easily be able to determine which component of the alternator is shot. It does not necessarily mean you need to immediately replace the whole alternator. Components may be replaced if available and if the component to replace would not cost more than just replacing the alternator with a fresh surplus. Checking if the battery is shot is equally "easy" for shops with the right equipment to check it.
    Point is, I don't see the need for a "hit and miss" on your problem. And considering yours is a Japanese brand vehicle and virtually new, that should be an easy fix.
    Try draining the water separator, check tightness of belt and check connection sa fluid reserviour and float.
    Check if you have brake lights, clean brake fluid reservior and float connection, clean 4 wheel speed sensors.
    Aug 2009
    Quote Originally Posted by 4JGtootsie View Post
    sir. i have brake light. brake fluid in the reservoir. what is float connection? clean speed sensors? im not sure kung malinis pa ung brake fluid.. wala po ung dmax dito po. nasa province po. have u encounter this problem? basta ABS, handbrake and airbag lumalabas kung tumatakbo. para after a few seconds or minutes nwala ung signal tapos balik na naman
    Once napundi 2 bulbs or nasira ang brake light switch or naubos brake fluid or mababa ang vacuum ng hydrovac ABS warning can be triggered. Speed sensors are magnetic, accumulation of metal particles will inaccurately send wrong signal to ABS module.
need help urgent (dash warning lights: all lit up)
