I just got a 2005 XUV. What kind of diesel do you usually use? Biodiesel or not?
Currently on Flying V biodiesel. Alternate choice is Petron Diesel Max.
Minola Cooking Oil. Used.
:hysterical:
Actually, I can use anything that comes from the pump. The Crosswind isn't too sensitive to diesel quality. Just watch for water contamination, as exposure to too much can hurt the fuel pump.
if you're in doubt with the response, drain your water separator once or every other month, depende sa gamit and make sure to fill up only to areas not known na binabaha.
when it comes to brand, barely unnoticeable difference in terms of response and FC, bigger factor will come from air and fuel filter condition and motor oil being use.
