Page 794 of 1213 FirstFirst ... 694744784790791792793794795796797798804844894 ... LastLast
Results 7,931 to 7,940 of 12125
    Oct 2015
    #7931
    Quote Originally Posted by Ogs View Post
    Ayos. Heheheh sige sir.. imeet ko xa sa july... peri bago ang lahat gusto ko muna sumali sa team ice. Heheh cant wait to join with the team. Hehehe nabigyan na aki ng background ni sir jessie at excited na ako sumali. Hehehe
    Back to topic.. egr... wala bang overheating pag nakablank na.. nabsa ko kasi na ang effect ay nag iinit ang makina. Any thoughts?
    Ok talaga yan si Jess. Mabait at napakahumble ;)
    Wala naman. Hindi rin naman tumataas water coolant temp when idling.
    Feb 2016
    #7932
    Quote Originally Posted by aar0nix View Post
    Thank you sir aaronix.
    Harold padura po
    Nov 2015
    #7933
    My own vanity list of upgrades.
    Naiipon lang sa bahay, galit na nanay ko sia kc nagrereceive ng parcels.
    Sent from my iPhone6s using Tapatalk
    Mar 2016
    #7934
    Quote Originally Posted by ikloyputograpi View Post
    Panalo list mo ng upgrades sir ah! [emoji1303]
    Oct 2015
    #7935
    Wow!!! OC 😱 hehe
    Mar 2016
    #7936
    Based on what I've read on Thai and Aussie forums, it's better to have the slotted egr blanking plate. I'm not too keen on using aluminum plates and removing the egr pipe. Aluminum can melt under hight EGTs. I don't want to risk it.
    Almost all answers regarding EGR Blanking of the new shape DMax and MUX can be found here:
    NEW D-MAX /MUX /COLORADO FORUM •
    It's a long, 17-page read.
    We should thank *ikloyputograpi for summarizing it for us.
    This confirms my observation after blanking about the EGR being fully open at idle vs before where it was just partially open at idle. ECU thinks that it needs to open fully the EGR valve because of the low volume of air coming from the exhaust port. Once I step on the throttle even at partial, the EGR fully closes. Before blanking, the EGR is always partially open all the time except only when WOT/Floored. Keeping the exhaust gases from mixing with the fresh intake air is important for a cleaner, sludge free intake manifold, intercooler, and turbo.
    I'm not saying this is gospel truth. The Australians have more experience than me, so I trust what they are doing.
    So far, I haven't seen my mu-x smoke anymore under heavy load. Before having it blanked, I usually get a puff of smoke whenever I start moving and floor it on first gear.
    Sorry baka may namiss ako, si kohn184 ba ay naka full blank or slotted?
    "Anyways fellas i am here to help out & answer any questions I can. I dont sell these plates for a living - its a hobby after seeing my intake completely clog up on my 4JJ1 about a year ago & figuring i should do something about it (something less than a $1500 intake clean & rebuild). I have used the money from selling plates to develop the full blank, with a full blank working I see my motor oil staying a lot cleaner. I have also used my knowledge to develop plates for other diesels & some petrols that my friends have.
    EGR is a great idea - however in reality if it will kill my engine in just 100,000kms i am not a fan."
    Tsaka parang wala ko napansin na egr cooler sa 4JK1-Tc(hi) engine natin?
    Ano pa ba difference nun sa 4JJ1 na released sa kanila?
    Dame tanong, alam mo naman na sir aaronix naka full blank nako, kaya mejo bias.hahaha
    Anyways, i would suggest ihuli nyo to sa upgrades.. Mahaba habang inuman, este usapan na kasi pag tungkol sa egr... [emoji38]
    Mar 2016
    #7937
    Share ko lang mga muxers.. This is how our egr pipe looks like,
    I am sure that our MuX here in ph do not have an egr cooler when we removed that pipe. i think the thermal insulation wrap is lame attempt to lower temp of air from our exhaust.
    I have around 9k in my odometer when this was removed and you can see in the pic how it looks like inside. i do not want any of that going into my intake manifold,
    I think that's where the big debate is sa AU, masyado extreme conditions nila in terms of driving offroad and even their weather, and it gets further complicated by an egr cooler and their sensors.
    I have yet to see how the thais have discussed this but just by principle, i would agree with khon184 - EGR is a great idea, but if it will kill my engine in the long run, or even add cost to have my intake manifold decarbonized/cleaned.. I'd go with full blank.
    Oct 2015
    #7938
    Quote Originally Posted by bluberto View Post
    EGR pipe of mux = EGR Cooler without the coolant passing through tubes. Our engines aren't that complicated.
    The link isn't saying full blanking is bad. Mas safe lang ang slotted plates vs full blanks or MAF attachments.
    Like I said, this isn't gospel truth, but I trust what more of them are doing (slotted blanking plates vs full blanking plates/MAF attachment)
    Nov 2015
    #7939
    this will not be debatable issue, because it will be still be at your own discretion whether to fully block the egr, no one is saying it is not correct
    because it also depends on your driving conditions,
    as for my own.. it is used as a family transport full city driving, cruisin around metro davao max 30kph,
    and the last time i've been there, my nanay's speed at most 20kph, due to volume of traffic, till i drove it around central then eastern mindanao for break-in'
    plausibly it will never experience a closed egr valve after that, it will always be partially or fully open,
    i can't take any risks of CEL showin up, because nanay wouldnt know how to fix it, thats why i'll choose a slotted plate by the time i'll install mine.
    since, you have already fully blocked the egr system
    would you do a simple experiment by running it idle for 10-15mins?
    because by that duration, we can confirm whether the ECU will indeed reopen the valve due to low volume of gases that comes from exhaust port?
    Nov 2015
    #7940
    Lets add a discussion/topic to the mix, regarding oil catch cans? To put a breather or not, i've seen a lot of post around TIP having a breather catch can. Or modified it to have a breather.
    I dont see the point of it, if in any case i dont want the vapor, to go back to the manifold, i would just condemn the line from can to the manifold. And also whether i need the can itself, can i just put a breather directly to the pcv port?
All New Isuzu MU-X // Alterra Next Generation
