You may use usb 30 pin or lighting cable, then plug it to usb port, ma detect na ng HU Ipod mo.
Mga boss tanong lang,kung malayo ang dealer na binilan or bibilan ng unit? puede ba gawin ang PMS sa other dealer (near by my area)..TIA
pwede po. nag check lang din sila sa dealer kung san ka bumili. nakuha ko unit ko sa bulacan, sa commonwealth ako nagpapa service.
Hello po sa mga MU-X owners and "want-to-be" owners like me.
Pa-suggest naman po ng dealer na ok ang offer for LSA unit for Bank PO (BPI). Nueva Ecija or Metro Manila areas po sana. If you can please send me text message din thru 0908 894 4981 if you can refer specific SA. TIA! More power!
City driving with moderate traffic 8-9km/l , pag driver nag drive 7-8 lang
2-weeks na ang nakakalipas until now still no stock ng Pearl white 4x2 automatic hayst..
SPO10kaloy same here waiting for pearl white..sa quezon ave meron binibigay sana kaso may DI 3%...i dont deal with DI..
Try mo kay ej sa makati galing din ako gencar. But bec of d.i. lumipat ako. In 1 month time nabigyan ako pearlwhite 09179072063 ej
Goodmorning mga sirs.. ask ko lang magkano inabot ng 10k km. PMS for mux lsa at anu ano mga ginawa? Tia!
*boybit sir bank finance po kayo? Pede ko malaman ang binabayaran nyo? How much downpayment and monthly? Magkano inabot lto / chatel / insurance?
Hello Mu-X owners!
Nache-check niyo po ba yung engine oil level ng unit niyo?
Yung sakin kasi, laging mas mataas dun sa 2nd dot nung dip stick.
Sa umaga ako nag-che-check, bago ko gamitin.
Thanks!
You don't need to check daily if engine is not leaking. You're just increasing the risk of particles getting in your engine.
Also luluwang yung cap nyan pag lagi binubuksan ung engine oil. Tatagas na nun.
You don't even need to check coolant level all the time on new cars. Once a month will do. If there's need to refill coolant then there's a leak.
Make sure the vehicle is on a flat area...if its slanted a little the oil level indication is not accurate..
Also read owners manual when to check oil. Some say after it is warmed up. While others say check when engine is cold. Maybe your reading is higher because you are checking your oil level when its cold.
