yep those are my vid/pics which i submitted to them, i set mine 27psi (there are 2 units bar & psi), before i drove out of the mod shop, we try to release the nitros also and it will notify if it goes below that point with beeping sound and will marked as red also. But if you are in the manila region, better opt for winterpines tpms so that your warranty will not be voided.
for my setup it is called d551 trophy black with anthracite ring, 20 x 9, +20 offset,
had a query on fuel offroad fb page and advised me to order it thru local distributor in davao which is tiresmart, probably they have the same supplier with BCC wheels in Banawe, kindly check thru their website for other galleries/details.
Mga paps air spencer
***yboy vs marine squash
Di ba masyado matapang ang ***yboy?
Thanks mga paps
Isuzu Naga ako sir nag pms.
Yes, the odo reading of your mux. 1st pms is 1,500km. Kahit ilang buwan na sasakyan mo sir basta hindi ka pa lagpas sa 1,500km parehas lang yan babayaran mo sa 1st pms.
Sent from my GT200 S using Tsikot Forums mobile app
Sir may i know how much ung tpms sensor sa winterpine or isuzu? Interested din ako pero concern ko baka nakawin un sensor. [emoji31]
Just to share, currently ang ginagamit ko sa MUX ko is a DIY TPMS its Steelmate TP-S1. External sensor ito nakakabit sa air valve and replaceable ang battery which will last for up to 2 years. The monitor is a solar rechargeable w/ backlight, may sensor ito during daytime off yung backlight, at night time glow in the dark sya. Auto off pag walang vibration sa auto. Alternatively pwede mo din gamitin micro usb to charge pag walang araw. Yung monitor nakalagay sa gitna ng dashboard.
Ang alam ko pag internal sensor kasi majority sa ganito is disposable at di pwede mag replace ng battery, already inquired sa winterpine and life span is only 2 years and the set cost around 15K. Gusto ko rin sana paganahin yung nasa HU TPMS pero knowing the cons ito na lang TP-S1 ginamit ko.
Inorder ko pala ito thru LAZADA, search nyo lang TPMS, cost around 7+K peso.
