Parang may buzzing vibrating droning sound coming from my HU. Started today pag lagay ng gps, took out gps but seems to be there pa rin. Any ideas ka tsikot?
Maganda kaya matte clear ang iwrap sa grille?
Sent from my LGLS996 using Tapatalk
Casa or outside Casa?
Sirs, wanted to know what is your take on this, my LS-A 4x2 is due for its 40,000km pms, I was told that this would cost me around P20thou, now I am torn between having it serviced in the casa or i will have it outside considering the high mileage already.
I am using it everyday logging around 100km/day, so far so good, no issues do date, satisfied LS-A owner here.
Thanks..
If you know a trusted mechanic then have the service done there otherwise stick with the dealer since you log a lot of kms daily. Better to be safe. You should also at least know a little about proper car maintenance and not just rely on the trusted mechanic. Try to search for recommended shops here in tsikot.
P20,000 sounds too much if you ask me.
Considering all that is to be done are within the normal wear and tear of the vehicle.
Do you have a breakdown of it its to be done on your Isuzu?
Never saw a clear matt before.
Para bang sa cellphone yung effect? A bit Icy ang dating?
Anyone tried to lift their ride mu-x whats the advantage and disadvantage??😃😃😃
Sent from my CHM-U01 using Tapatalk
Mag kaisa lang po ba ang cabin filter at aircon filter?
Saan kaya pwede mag palagay? Sa casa ba pwede?
Sent from my GT200 S using Tsikot Forums mobile app
Guys on our mux what is the acceptable computations of changing tires if i want to change what are the limit computations or acceptable conversion measurement kung 20" and 17" na mags.. ...mags and tires?😂😂
i usually use this when shopping / day dreaming for tires
Tire size calculator
Mga sir,para saan po ba yang horn na yan?
Sent from my B1-A71 using Tapatalk
Sa 17" max size without rubbing is 265/70/17 (using oem wheels)
Sa 20" 265/55/20 max offset 0
Anong unit? Sa LS/LSM max file resolution is 480p.
Sa LS-A alam ko 720p. Hindi rin naman high def yung monitor kaya no use ang 1080p videos.
Pinaka maganda .mp4 format, most of my videos work with that.
Para sa alarm/immobilizer:
How an immobilizer system works on Isuzu MUX LS-M - YouTube
Ok, thanks again for the info, LSA ang unit ko.
3.0 4x2 AT
363 kms
29 litters
363/29 = 12.51724 kms/l
FT to FT
