Results 11,321 to 11,330 of 12125
March 8th, 2018 12:13 AM #11321
Un ang point ko. Wala ako dyan sa metro manila. Pede ko gawin yan italian tuneup kung kelan ko gusto.
Same driving habits pero ramdam ko talaga na may nagbago from 10w30 to 15w40. Even sa fc, nanghinayang naman ako na idrain kagad, pero kating kati ako na ibalik sa 10w30.
Di kagad ako nag 5w40 kasi nga di kasama sa recommended lists. Kaya nagsearch ako sa ilang websites ng oil companies kung ano recommended nila
Sent from my R7plusf using Tapatalk
March 8th, 2018 12:21 AM #11322
By the way di ako nagpapaservice sa banawe o casa. Home service, tsaka sure naman ako na authentic un oil na nabibili ko.
Nawalan kasi ako ng gana sa casa. Lahat halos ng bolts ng oto ko, sobrang higpit, kaya kadalasan un drain plug nalolost thread kagad. Puro ojt ba naman tumitira... Tsk tsk
March 8th, 2018 12:41 AM #11323
March 8th, 2018 12:54 AM #11324
you can get an obd2 reader and check coolant temps at 40c ambients and 20c ambients.
Engine Cooling System - YouTube
Sent from my SM-G935F using TapatalkLast edited by StockEngine; March 8th, 2018 at 01:03 AM.
March 8th, 2018 01:20 AM #11325
Bro, i have an obd scanner too but for oils, i follow this chart which is in all car manuals naman. It follows outside temperature. Though i never encountered any major engine trouble in all our cars ever. (Well except my dad's santa fe that needed a top overhaul at 125k kms)
Here's what i follow:
March 8th, 2018 02:06 AM #11326
March 8th, 2018 02:15 AM #11327
- Mar 2018
- 13
March 8th, 2018 04:33 AM #11328For info what the SAE codes are for.
For example: 15W40
15W - oil viscosity at cold start
40 - oil viscosity at 100 degrees celsius (normal running engine temp)
The thinner the oil visco the faster it will be distributed to moving parts inside the engine at cold start to prevent wear and tear. But should be thick enough to coat the moving parts to prevent wear at 100 degrees temp of a running engine. So stick to manufacturers recommended visco.
March 8th, 2018 08:22 AM #11329
Pero un ipinadala ng isuzu sa mt.everest 15,000 km challege na 5dmax 5w40 ginamit ng team nila. Pati sa paris dakkar rally
March 8th, 2018 08:50 AM #11330
Basta usapang langis di talaga matatapos ang usapan kaya stick na lang tayo kung saan panatag ang mga kalooban natin
Yung extra AUX Fan is useful sa mga naka montero. Mag improve daw yung AC system since may extra...
