Results 1 to 2 of 2
- Oct 2010
- 5
May 2nd, 2012 09:46 PM #1good day!
newbie ako dito sa tsikot and I'm from Davao city, i owned an isuzu bighorn xs manual (japan) with 4jg2 engine. i have some queries sana masagot:
1. What might be the problem na when mag trip off ang A/C or off mo na A/C instead na magtaas ang idle ng makina parang na cho-choke ang engine and may sudden vibration; and
2. What is the effect if the timing belt snaps or breaks? Mag-aabot ba pistons and valves as what will happen to other belt-drive engines like 4d56 of mitsubishi?
Hoping for a informative reply from other members.
thank you in advance.
May 17th, 2012 02:57 PM #2
sir pa check nyo po iddle up valve if working properly.
If si timming belt naman, alam ko if ever maputulan ka nito masakit sa bulsa ito
***y welds! Apparently the subcon that makes the part replaced a worn welding tip but did not...
Chery returns to PH
