Results 1 to 2 of 2
- Oct 2010
- 5
May 2nd, 2012 09:46 PM #1good day!
newbie ako dito sa tsikot and I'm from Davao city, i owned an isuzu bighorn xs manual (japan) with 4jg2 engine. i have some queries sana masagot:
1. What might be the problem na when mag trip off ang A/C or off mo na A/C instead na magtaas ang idle ng makina parang na cho-choke ang engine and may sudden vibration; and
2. What is the effect if the timing belt snaps or breaks? Mag-aabot ba pistons and valves as what will happen to other belt-drive engines like 4d56 of mitsubishi?
Hoping for a informative reply from other members.
thank you in advance.
May 17th, 2012 02:57 PM #2
sir pa check nyo po iddle up valve if working properly.
If si timming belt naman, alam ko if ever maputulan ka nito masakit sa bulsa ito
unless sira the lock, most car door locks are designed to make it more difficult for you to lock...
