Have a problem with my Isuzu Crosswind XTi. Around late November last year, I noticed a problem with my Crosswind which steadily and progressively worsened. It started out when I felt there was a slight delay when I started the engine. This then progressed to it wouldn't start at the first click of the engine but second and later on maybe third or fourth time I switched the ignition on. Then when I was driving it, I felt there was a feeling of sluggishness during the early days of the problem until it worsened to the point where on drives the rpm would go down and the engine stalls and I would stop and need a minute or 2 to start up the engine again. It progressed to the point where I would stall 3-4 times.
On December 29, 2012, I decided to have it serviced at Isuzu EDSA Balintawak. They managed to fix it and told me it possibly was a belt problem. So for a month and a half I used it normally until this Thursday Feb. 14, 2013 when I felt the delay again and today, I noticed the symptoms I described above coming back. I will be bringing it back to Isuzu EDSA Balintawak again tomorrow but I would like to know if anyone has had this problem and what could be causing it. Last December, they parts they replaced were the following:
1. Gasket, drain plug;
2. Plug, drain, fuel tank
3. Oil filter element
4. Fuel filter element
5. Belt, cooling fan
6. V-belt and
7. Repair Kit, CLU slave cylinder.
It's a 2007 model and not much smoke is coming out so not sure if it is calibration related. Hope people can help me diagnose the problem.
baka naman mababa lang yung menor mo?
have you tried turning the li'l black knob at the lower left side near the steering wheel? turning it clockwise will increase the rpm. you can use it for the meantime to
adjust to the desired rpm.
hth!
check you water sedimentator baka may tubig or barado na sya... nozzle tip palinis mo din ... then also agree with sir holdencaulfield check mo menor mo.
replace fuel filter and check the sedimentator. ganyan din nangyari sa sportivo ng friend ko. check mo rin yung diaphragm dun sa pinagkakabitan ng fuel filter.
Have you found the solution? I have already changed my Fuel Filter and drained the Sedimentator. Can you please help me? Do you know any good Isuzu Mechanics in Q.C.?
