Results 1 to 5 of 5
    Our Crosswind XTO hit 40K recently. We'll be changing the tranny fluid and differential fluid (already changed the oil along with filters, and brake fluid).
    Can anyone give me info on how many liters of ATF (Dexron II-E right?) is needed (the manual gives the full capacity AFAIK but not all can be changed since some is left out in the torque converter). Also, how many liters of diff oil (GL 5) is needed?
    manual transmission 1.5 L
    differential 3 L
    Automatic trnsmission 1.5 L
    differential 4.5 L
    Whoa... 1.5L lang pala kelangan. Good thing i checked first. The owner's manual states around 5L more or less for the tranny if i remember it right (that much is left in the torque converter???).
    The a/t tranny differential needs more differential oil then the m/t... wasnt aware of that before.
    Thanks!
    nag inquire ako sa IADI 1,200 differential and transmission oil and labor for manual tranny
    Thanks!!!
    Just to add, we've already changed the tires on ours to the 215/65 R15... Mas maganda yung stance and feel IMHO. Next thing to do is to check on the somewhat excessive freeplay on the steering.
Crosswind Fluids
