Results 1 to 19 of 19
    Jan 1970
    I've tried in vain to remove stains or discoloration in the panels but no luck. It looks like UV damage cause it only occurs in parts that are dirctly under the sun.
    What paint can I use that won't easily scratch off?
    vinyl paint i think. ask mo sa paint shop they know what to mix.
    ito ba yung mga panels tulad ng nasa aircon or sa may center controls? kung yes, pwede pong ipapintura. aks mo nalang sa local paint shop mo tulad ng sinabi ni afrasay.
    most likely ay ibig mong sabihin ang dash boar in general ?? yup , may paint na ginagamit diyan na will last long basta maintain mo lang ng coatings like from armor all etc .... forgot the name but its the one used for hobby shop paint . i had mine painted and has been a year and a half now , walang biyak biyak or nag fade na kulay . give it a try .
    tamiya paint ata pwede.
    Jan 1970
    Ok. thanks guys...on to my next project!!!
    sa wakas may nagtanong din ng interior paint...whew...
    ung mga nagpa paint sa inyo, aside sa pinagawa nyo sa paint shop, ano pa ba pwd?kasi ako nagkamali...i tried painting the interior using pylox..kala ko nung una ok...tapos beginner so mdyo sagwa...pro after some time...natutuklap...
    meron po ba?
    tska kung paint shop tlga, may marerecommend kayo?hopefully sa may south area...thanks!
    Jan 1970
    meleagant8...
    how did u paint ur interior? dapat after each coat, ipapa-dry mo muna. then sand it with wet 2000 grit sandpaper. then apply the next coat... mga 3-5 coats dapat. at dapat manipis lang ang spray sa bawat coat.
    ah...di ko ginawa un...
    spray lang...tapos patuyo konti spray ulit...mga 2 coats lang ata un...
    so ok lang kung pylox ang gagamitn ko pra sa interior ko?or meron tlgang interior paint para sa mga kotse?
    so gagawin ko, first coat tapos sand with wet sandpaper then next coat?
    tska ano maganda pangtanggal ng paint sa mga platic trim panels ng car?kasi medyo may mga lumalagpas na paint na sagwa tignan eh...
    Jan 1970
    FOLIATEC na interior spray... 600+ ang isa. meron din sila primer spray. I didn't use this kasi mahal.
    yung sandpaper mo dapat high-grit... mga 2000. u can find these at Hans Tools sa Shangri-La mall.
    i forgot to mention, dapat pala i-sand mo muna yung i-pe-paint mo. sand it with mga 800 grit na sandpaper bago mo i-paint. tapos after each coat of paint, let it dry ng mga 10-20 mins... then sand it with a wet, 2000grit sandpaper. make 3-5 coats depending on what you think is alright.
    lumagpas na paint??? di mo tinanggal muna yung trim panels mo bago mo pininturahan? oh, no! u should have removed it first. ako nga, eh. di ko pa ma-paint yung center trim kasi di ko matanggal sa dashboard, eh.
    i think thinner will do the trick. careful ka lang... and be prepared to have a weird smelling car. bili ka ionizer para mawala yung smell afterwards...
    thanks fenris...
    san ako makakabili ng foliatec?sa hans tools lang ba?
    layo kasi e...sigruo any shop sa makati or south are preferebly sa bandang paranaque sana...
    thanks sa tips..
    sana nga makuha nung thinner e...actually di gaano kahalata kasi black naman ung color ng paint eh...
    problem ko lang is ung part ng radio at ung sa may lighter...di ko matanggal kasi ung lighter sa loob ng car e...di ko tuloy mailabas ung panel...
    ung lumagpas...sa door panels lang actually...kasi ung gitnang panel lang ng door ang ipapaint ko...e di mo mababaklas ung gitna ng door kasi...
    ei fenris, other that sa hans tools, san pa may foliatec?kasi...ala ako masyado time makapagikot e...busy sa sch kasi...
    Jan 1970
    Thanks for the tips guys.
    Jul 2003
    foliatec marami sa CONCORDE, 3rd fl., SM Megamall. mahal nga talaga yun lalo na dun, but maraming variations/colors. may iba ring foliatec products like panel trims (e.g. aluminum, wooden, etc.). please post results/comments, baka try ko rin. thanks!
    kung sa plastic interior panels, mas maganda gamitan nyo ng plastic primer, follow first the intructions of fenris tapos spray na ito....patuyuin mo after a few days saka mo bugahan ng paint....
    mas madali ang trabaho kapag binaklas mo yung part na pipinturahan mo kaysa takpan mo ng buong dyaryo yung buong car interior
    Jun 2003
    sir chieffy after plastic primer pwede na pylox? where can i buy plastic primer?
    do you do painting of dashboards in your shop?
    Jan 1970
    meleagant8,
    check out my gauge cluster. pylox yan. almost 2 years na, so far wala pa naman crack.
    http://www.pbase.com/image/20265688
    Jan 1970
    Foliatec has primer coating for interior trim panels. Para kumapit ang paint dun sa plastic.
    Pero kung kapos ka sa budget, kiskisin mo muna ng 600-800 grit na sandpaper yung surface... punasan mo ng mabuti bago mo sprayan ng pylox.
Can you paint plastic interior trim panels?
