Results 1 to 10 of 19
- Jan 1970
- 164
June 19th, 2003 11:41 AM #1I've tried in vain to remove stains or discoloration in the panels but no luck. It looks like UV damage cause it only occurs in parts that are dirctly under the sun.
What paint can I use that won't easily scratch off?
June 20th, 2003 12:18 AM #3
ito ba yung mga panels tulad ng nasa aircon or sa may center controls? kung yes, pwede pong ipapintura. aks mo nalang sa local paint shop mo tulad ng sinabi ni afrasay.
June 20th, 2003 07:01 AM #4
most likely ay ibig mong sabihin ang dash boar in general ?? yup , may paint na ginagamit diyan na will last long basta maintain mo lang ng coatings like from armor all etc .... forgot the name but its the one used for hobby shop paint . i had mine painted and has been a year and a half now , walang biyak biyak or nag fade na kulay . give it a try .
- Jan 1970
- 164
- 237
June 23rd, 2003 09:14 AM #7sa wakas may nagtanong din ng interior paint...whew...
ung mga nagpa paint sa inyo, aside sa pinagawa nyo sa paint shop, ano pa ba pwd?kasi ako nagkamali...i tried painting the interior using pylox..kala ko nung una ok...tapos beginner so mdyo sagwa...pro after some time...natutuklap...
meron po ba?
tska kung paint shop tlga, may marerecommend kayo?hopefully sa may south area...thanks!
- Jan 1970
- 25
June 23rd, 2003 10:51 AM #8meleagant8...
how did u paint ur interior? dapat after each coat, ipapa-dry mo muna. then sand it with wet 2000 grit sandpaper. then apply the next coat... mga 3-5 coats dapat. at dapat manipis lang ang spray sa bawat coat.
- 237
June 24th, 2003 12:56 PM #9ah...di ko ginawa un...
spray lang...tapos patuyo konti spray ulit...mga 2 coats lang ata un...
so ok lang kung pylox ang gagamitn ko pra sa interior ko?or meron tlgang interior paint para sa mga kotse?
so gagawin ko, first coat tapos sand with wet sandpaper then next coat?
tska ano maganda pangtanggal ng paint sa mga platic trim panels ng car?kasi medyo may mga lumalagpas na paint na sagwa tignan eh...
- Jan 1970
- 25
June 24th, 2003 04:31 PM #10FOLIATEC na interior spray... 600+ ang isa. meron din sila primer spray. I didn't use this kasi mahal.
yung sandpaper mo dapat high-grit... mga 2000. u can find these at Hans Tools sa Shangri-La mall.
i forgot to mention, dapat pala i-sand mo muna yung i-pe-paint mo. sand it with mga 800 grit na sandpaper bago mo i-paint. tapos after each coat of paint, let it dry ng mga 10-20 mins... then sand it with a wet, 2000grit sandpaper. make 3-5 coats depending on what you think is alright.
lumagpas na paint??? di mo tinanggal muna yung trim panels mo bago mo pininturahan? oh, no! u should have removed it first. ako nga, eh. di ko pa ma-paint yung center trim kasi di ko matanggal sa dashboard, eh.
i think thinner will do the trick. careful ka lang... and be prepared to have a weird smelling car. bili ka ionizer para mawala yung smell afterwards...
It sounds like a potential headache for the unlucky ones that got their units from EV solutions PH...
Hybrids and EV
