Results 1 to 20 of 26
    while still hot inside, you may turn on the fan without the AC ON to circulate the hot air inside the evap and vents for a couple of minutes.
    Quote Originally Posted by benchman View Post
    Wow! Thanks for the tip
    Dec 2009
    Beware of battery voltage drop
    Jun 2004
    The mold could have grown in the vents, inside the dashboard, under the seats and in many other spots.
    Had the same problem a few months ago.
    Spray some Lysol. When using the car drive with all windows down unless madami snatchers sa area.
    May 2018
    Sis Cathy, I hope you had the carpets and seat covers washed too (as we advised dati).
    As for the spores ng mold in the vents and A/C system, better have it professionally cleaned if tinatamad ka mag DIY.
    Sep 2010
    Ma"papatay" kaya ng Microtec Bac-to-zero yung molds sa car interior ni Ms. Cathy?
    May 2018
    Quote Originally Posted by timtonymanu View Post
    I'm not sure what's the active ingredient in that product.
    It would be safe to say however, that in the right concentration, most commercial disinfectants will kill, or inactivate the majority of microbes if they're exposed to it for a sufficient amount of time. No disinfectant will be able to kill all 'germs' however.
    Just note though that killing the mold and spores (ie. it's 'seeds') are important to prevent them from spreading, but even when "killed", they still remain a health risk because they can cause adverse reactions in people (allergies, etc.), so physically cleaning them off the surfaces they're on is still important.
    By the way, wag kayo masanay gumamit ng mga disinfectants/antibacterial products & soaps lagi. On an 'as needed' basis lang. In most cases, basic hygiene (plain soap and water) will suffice.
    Humans are not meant to live in a 'sterile' environment.
    not healthy imo. how long does the active ingredient stay active? poison ☠
    May 2018
    Hindi naman siguro. When used as indicated.
    Yung rubbing alcohol that people commonly use, that's poisonous naman din, but you're not supposed to *drink* it right?
    More likely, aerosolised Ethyl Alcohol lang yan (parang Lysol spray), packed in a sustained release cannister na single use.
    Aug 2017
    Quote Originally Posted by SoleusBB View Post
    Isn't Lysol a scam? Hehehe
    This I found on YouTube... Been using it for 3 years now, every 6mos on all my GrabCars
    AMAZING Way To SUPER CLEAN The NASTIEST Carpet ! - YouTube
    DIY cleaning solution :
    1 scoop OxiClean
    2-4 tbps Ajax dishwasher (aka Joy)
    3 tbsp rubbing alcohol
    6 tbsp of glass cleaner with ammonia
    Fill with hot water to make a gallon
    Make a small hole in the gallon cap to allow the OxiClean to bubble
    1) Pour to flood on and brush carpet
    2) Soak for 2hrs
    3) brush again, repeatedly soak and brush as necessary
    4) Flush with running water, simultaneously vacuum out
    5) Dry for 5days with doors open
    go the extra distance.. use the heater
    we don't have heaters here. meron ba altis?
    as far as i know
    meron
    ang wala yun avanza.
Mold on Car Interior
