Results 1 to 10 of 21
- 4
October 24th, 2002 10:15 AM #2
dami...
basic will include vacuum, brushes, organic and petrol based cleaners, dressings and towels.
October 25th, 2002 06:59 PM #3
:?: ask ko na rin kung saan maganda/magaling magpalinis ng ceiling?
thanks!
October 25th, 2002 08:15 PM #4
it's not that hard... if you want I can do it for you, mura lang ... :o
seriously, if you have the time, do it yourself, punta ka sa store, bili ka ng Turtle Wax Upholstery Cleaner, grab 4-6 towels and scrub away... mga 2hrs or more ang ceiling headliner...
- 237
October 27th, 2002 05:51 PM #5sir theveed
my ninong washes his ceiling by using a sponge and water-soap solution...
safe po ba un?
October 28th, 2002 11:12 AM #6
not really, the headliner is attached using adhesives, madalas nasisira ang adhesive pag nababasa, that's why most DIY products are foamy... Pag nasira yung adhesive the headliner can droop down and collapse...
as long as the headliner isn't soaked or too dampened with liquid, it should be ok, but it's still best to avoid wetting the headliner... (unless vinyl lang sya, in that case, it's more tolerant to moisture)
- 237
November 1st, 2002 02:00 AM #7thanks....i might try turtle wax interior cleaner....hmmm....sana mura lang siya....
- 61
November 5th, 2002 09:12 PM #8about 220-250 php yung turtle wax interior cleaner sa concorde.:wink:
November 5th, 2002 11:56 PM #9
If I remember correctly, TW Upholstery Cleaner is indeed cheaper in Concorde than in ACE, I suggest you check the prices at Ace muna (basement) before going to Concorde, yung Tire Gel sa Concorde mga P50 more than ACE...
April 14th, 2005 11:00 AM #10
anong pwedeng gamitin na cleaner for the dash and other plastic / hard surfaces?
may glue residue rin kasi from the clear plastic cover of the HU.
high idle RPM at engine start
