How do you clean your navi screen? Is it safe to use meguiars quick interior detailing on those?
Just wipe it with a microfiber cloth.
if you have the free cleaning stuff from eyeglasses, baka pwede yun
Sent from my Mi A1 using Tapatalk
Microfiber towels will also work. I have a spare one on standby sa tabi ko. Pampunas sa HU screen tsaka power window switch combination kapag nabasa ng ulan.
Plain damp cleaning cloth. Pag wala, baby wipes. Pag talagang madumi, tissue paper dampened with alcohol.
Or buy ka nung pinagbibili sa computer stores na cleaning cloth and liquid set for lcd screens.
Just do not press too hard as you might break the liquid crystal.
The first thing you need to do is to make sure that the screen in your car is turned off. This will also allow you to see dirt, dust, and grime better. You can use a microfiber cloth to wipe your navigation screen. If needed, you can spray some alcohol-free screen cleaning solution to the cloth then wipe your navigation screen. This is to avoid scratching the screen. However, if you're not sure and confident doing it you can just visit your trusted car shop to do the job for you. Hope this helps!
Dont use alcohol..read your LCD TV manual
Sent from my SM-G532G using Tapatalk
I'd use water-Joy-isoprophyl alcohol solution.
You will rarely scratch the LCD screen itself because there is a polarizer film on top of it.
You can actually replace that film when scratched. I did in my in-laws' old LCD TV.
Damp microfibre cloth to remove smudges. Dry microfibre cloth to remove dust. That is speaking from experience with an almost 10-year old Kenwood 2DIN HU that has been through two vehicles.
As much as possible, avoid using any concoction of chemicals or cleaning fluids. The heat, the humidity, and the sun (UV) might react to the residue and could cause some problems in the long run.
Only exception is if the screen is made of glass... then it should be impervious to anything you throw at it.
