Results 1 to 10 of 16
    Jun 2012
    Guys pano nyo nililinis ang headliner nyo?
    I've seen video sa youtube na gamit daw ng rinseless na detergent. Anong brand ba yung may rinseless na detergent?
    Medyo lagi ako naka windows down kaya medyo maitim na yung mga kanto kanto ng headliner eh.
    Aug 2008
    Quote Originally Posted by Roden Villegas View Post
    The main issue with headliners is that you don't want to get them too wet, as this will degrade the glue holding the headliner to the car body and cause the headliner to sag. Here's how I clean mine:
    I use an all-purpose cleaner (APC) diluted for interior use - an option that's readily available would be Microtex's Quickleen - and spray the cleaner on a microfiber towel - not on the headliner directly! - and then use the towel to wipe the headliner, in gentle, straight-line strokes. You'll see dirt and grime accrue on the towel - as necessary, re-apply your APC and/or change to a fresh side of the towel. Once done cleaning, do a final wipe-down, this time using a towel slight dampened with water, to remove any residue left by your APC.
    Jun 2012
    Thanks papa.
    I'll buy Microtex Quickleen.
    As I visualize yung direction on cleaning. Parang medyo matrabaho ah :D Time consuming at nakakangalay sa leeg
    Jun 2011
    yup ive tried APC sa 1995 mazda 323 namin, works well, parang bago lang yung headliner nya. be careful though kasi pag sobrang pauli ulit mo gamitin the headliner gets thin as well to the point na masisira sya. well just a hunch baka sobrang luma na nung sa 323 namin kaya ganun nangyari. best to try first on a small area, sa likod ka start para if ever something goes wrong d halata.
    Aug 2006
    Ibang style naman nakita ko sa Shell - Kalaw Hills, gamit nung detailer eh abaca brush yun nabibili sa palengke, lublob nya yung dulo ng brush sa APC then hagod sa head liner in uniform stroke and direction, amazing pag dinaanan nung brush nahuhulog yung dirt sa brush at yung headliner natatanggal yung grime. Yung headliner hindi gaanong nababasa at no need to vacuum dry. Pag yung detailer ang gumagawa parang very easy, pero malamang masakit sa braso yan at sa leeg.
    Jun 2012
    Tried cleaning nung weekend with Quickleen.
    Hindi immediate ang result kaya napapadiin punas ko. Ayun kinabukas ng matuyo, puro himulmol Hehehehe.
    Narealize ko na ang paglilinis ng headliner ay hindi pwede sa mainipin
    Paano or Anong need gamitin to minimize himulmol while cleaning the headliner? Ok na ba kung microfiber cloth lang? What other alternative sa Quickleen?
    Feb 2009
    Quote Originally Posted by sphinxz View Post
    Electrical contact cleaner and dust off. No residue and quick drying
    Aug 2009
    Saan nakakabili nito bro? Hindi ko sya napapansin sa concorde or blade nor true value salamat
    Feb 2009
    Dust off should be available at computer stores brake parts cleaner at hardware stores or auto parts stores
How to clean headliner?
