Results 1 to 10 of 10
    Oct 2009
    Mga sirs saan maayos magalign at gumawa ng door hinges? Hindi na kasi pantay mga pinto. Metro manila area. Thanks.
    Its welded, no adjustment yan. What car and year? Door seals replaced?
    may collision? sometimes it's the car door frame structure itself gone warped. pwede rin nag-flexed yun pinto.
    I'm also interested, dang motorcycles!
    Jan 2009
    Car make and model? On older cars, the hinge pin wears out causing the door to sag.
    Anyway, there's usually a way to align the doors but the method can vary between different makes and models.
    Jun 2011
    Quote Originally Posted by eurostyle View Post
    Rebuild Lang nila door hinges... Mura Lang yan
    Oct 2009
    89 nissan 720 dcab sirs. Yes nagssag na nga siya. Parang maluwag na un turnilyo sa bisagra.
    Oct 2009
    palit bushing ang bisagra..napapalitan yan..
    if the culprit is just the door hinges and not door deformation...
    as jaypee says, it can be repaired or replaced.
    replacing the bushings inside can be done. or buy rebuilt or new hinges. ask the folks at the cathay centers in evangelista or banawe.
    afterward, it takes just a wrench, one or two assistant muscles, and a lot of patience, to align the door. or you can pay them to do it for you.
    but if the door itself is the cause of the mal-alignment... collision or rust... it will take a very skilled latero... or you may have to get a replacement door.
    btw... the folks' motto is "get the most from your customer". so if you know somebody familiar with the business, get him to accompany you.
    i was once asked a thousand bucks, for a job that normally runs for 200 ...
    good luck.
    Oct 2009
    Thanks dr d. And sa lahat po ng nagresponse. Wala po problem un door. Maluwag lang un sa bisagra or baka sira na ang bushing.
Door hinges
