Results 1 to 11 of 11
    Feb 2009
    Good pm Tucson ix owners...
    I just have my new Tucson GLS AT and moving now for 13 days from the day I took it at Hyundai Commonwealth.
    Going straight to my problem is the two (2) remote key which is now unusable due to unknown reason. "Di na sya gumagana". I've just used the 1st key for 2 days and the 2nd key for 9 days only. After that, wala na silang silbi.
    And one thing I noticed is the smell of the two key which smellls as burned (sunog) pcb/electronics. Di ko alam kung may nag short circuit or what. The worst thing of course is, di ko na sya magamit. I used it now manually to open and close my unit. Up to now wala pang tawag si Hyundai to check or repair the key. Grabe. Anyone here who has the same problem? Thanks.
    Feb 2009
    Well Well Well... DIY na lang ginawa ko. I just replaced the battery with a new one and apply the powerful McKenic 9-in-1 contact cleaner. Result... OK Working na ulit ang dalawang remote ni Tucson...
    Mar 2007
    ung remote naman ng tucson ko topak din.ang hirap i-arm at disarm minsan.you have to press the button several times bago magarm o disarm.ganun din daw sa tucson ng pinsan ng gf ko.bakit kaya?parang hindi maganda ang code alarm.
    Aug 2006
    Quote Originally Posted by dcarlo187 View Post
    Did you try pressing it hard 3-5 seconds?
    Code alarm din ang sa Tucson Gen1 ko at kailangang i-press ng ilang segundo para "kumagat".
    Feb 2009
    gud pm ulit mga fellow tucson owner....
    guess what? after gumana ulit nung remote ko eto na naman....putik sira na naman
    and this is what i discover... bumili uli ako ng battery, tapos yon pwede na naman ulit.
    16 days tumagal yung battery sa parehong remote. i'l will count again for the number of days kung ilang days ang itatagal. kung ganon ulit... well problema na talaga to ni Hyundai
    Baka naman grounded ang remote ninyo, Sir, kaya mabilis maubos ang battery.
    Feb 2009
    Quote Originally Posted by IceT View Post
    i will check kung grounded nga. pero kasi dalawang remote sabay halos maubos ang battery.
    Feb 2009
    positive po na may problema talaga itong remote ng tucson ko.
    after 8 days of counting. ubos na naman ang battery nung remote
    hayun... manual na ulit ang close/open ng doors.....grabe talaga
    Sep 2010
    Ito rin problem ng keys ko.
    San makakabili ng McKenic 9-in-1, sirs?
    Jun 2007
    hindi ba covered ng warranty yung key?
    Sep 2013
    To the other owners, did you encounter this problem? well I guess defective yun remote nyo sir? any update now? TIA!
Tucson Remote Key Problem
