Results 1 to 18 of 18
    Mar 2003
    how do i do this folks?i've seen many vans around w/ its spare tire wrapped by chain secured by a padlock , gano kahaba yung chain na dpat gamitin?tsaka san maganda i-wrap yung chain?(is der a beam there underneath na pwede pagtalian?tnx 4 ur replies in adv, i havent chekd our van's underpinnings yet kac nasa province ito :D
    momoyster,
    Just buy a chain-type bike lock para built in na yung lock and may plastic wrap ang chain. Dalawang type iyan, yung cable type (usually by Master) and yung chain talaga (usually made in China). Yung chain mas mahirap putulin.
    Hindi ko rin alam how the underchassis of the Starex looks like pero malamang may mapaglalagyan ka naman dun. Sa Besta dati binilot ko sa chassis and basket so that the basket will not lower kahit madefeat nila yung bolt ng basket.
    Also, place the lock as high as possible para medyo mahirap dukutin and to protect it from the elements. Grease it to prevent rusting and seizing up.
    I use the Master chain with wrapping on my pick-up It costs more then a regular chain but it does keep the links/cable from corroding... and its still much cheaper then shopping for a replacement spare tire and rim.
    Use also a good, heavy duty, and corrosion resistant padlock like Solex, Master. etc...
    Mar 2003
    tnx 4 ur replies sirs :D mga magkano ba usualy umaabot yung chain at lock? tnx uli
    share ko lang.
    yung sa starex namin, never na nilagyan ng chain and lock yung spare tire.
    located kasi sa rear bottom portion ng van.
    tapos kelangan pa gamitan ng tire wrench para lang maibaba yung gulong.
    hassle nga magpalit ng goma eh.
    la lang.
    ni-share ko lang naman.
    :mrgreen:
    I think i spent around P700-P800 for my Solex padlock and Master chain.
    Jappy, you mean the socket to bring down the spare tire of the Starex is inside the car (below the rear door)? This would make it harder to steal then since the ones that are easily stolen are those with the lowering mechanism accessible outside/below the car... unless of course they can deflate the tire and make it fit through the cradle.
    One way to find out kung nakawin yung spare ng Starex is to go to the shops in Blumentritt and near Banawe and count how many Starex rims they have there. When my Frontier spare was stolen, i went to those small shops and i counted quite a lot of used Frontier rims in different conditions and different finishes... sigh.
    P300 for the 2 meter chains, P200 for the all-weather padlock.
    Kinabit ko po yung kadena sa isang rear bar just below the Starex body. Yung ibang sobrang kadena pina-ikot ko sa tire carrier pati na rin sa gulong. It is much easier if you could get it lifted sa gas stations para alam nyo kung san isasabit yung kadena. Mas maapapdali ang pagtanggal at pag alis ng goma kahit may kadena kung tama yung pagkakapalupot ng kadena. :mrgreen:
    vinj::: Sa ilalim po ng body yung bolt ng reserve tire carrier ng Starex vans. Not like L300's which is inside the cabin.
    Yup, pwedeng ibaba ang tire carrier ng Starex even without opening the tailgate. Ang eng-eng, noh? Hehehe. Nakita ko dun sa Club 4x4 na tinest drive ko.
    opo.
    accesible sa ilalim.
    sorry medyo mali ata yung pagkaka-type ko.
    hehehe
    Mar 2003
    share ko lang kakabili ko lang nung solex na rear spare tire lock. P899 sa may Garage Sta Lucia, Cainta. Thought of buying the Yale chain with lock P500+ sa true value kaso baka 1 snap lang to sa bolt cutter. Ang fear ko naman sa solex lock na ito baka hampasin ng hammer so its either mayupi hanggang mapunit yung stainless steal. I dunno pero siguro ilang hampasan to bago nila maalis ito. 8O
    Mar 2003
    yung solex rear spare tire lock yung lug lock type. You need the key before mo maikot yung lug lock. dami ko nakikita na bago CRVs na di secured yung rear spare tires. Sabi nung isa owner na tinanong ko sabi niya confident siya dun sa alarm ng sasakyan niya. Hmmm me point siya pero mga hudas na magnanakaw ngayon are really getting smarter nowadays.
    with my starex,
    i didn't use chains..
    i had to bars welded sa body at sa tire carrier..
    dun ko nilagyan ng padlock.
    OT: sir Ungas,
    ganda ng sig mo!!! 8O
    GRABE!!!
    8)
    OT:
    wreckless:::
    Salamat po ma'am. :D
    You can still take out the CR-V's spare tire even with an alarm. Just don't do any sudden/jerking movements. The shock sensor of most aftermarket alarms are located on the driver's side footwell. Far from the spare tire. Does the OEM alarm have a shock sensor?
    Mar 2003
    sir ungas,
    wen u say "rear bar" r u referring to the horizontal bar in between d spare tire basket and d rear differential? dun ko rin kac naisip na itali e, kaya lang naisip ko na baka gumagalaw din yung bar na ito kac mukang part of the suspension.dun nyo rin ba itinali yung chain ng sa inyo? tnx uli:D
    momoyster,
    Hindi ba lateral rod ng rear suspension yang sinasabi mo? Hanap ka ng part ng chassis.
    Quote Originally Posted by momoyster
    sir ungas,
    Nope not that part. What you are referring to is the rear panhard bar. Yung sinasabi kong rear bar para siyang cross member ng chassis located under the body. Lalo bang gumugulo kasi ang Starex vans ay monocoque body. :D
    Try to have it lifted in your suking gas station or any lifter will do while the reserved tire is removed. Dun nyo po makikita yung isang bar located above the spare tire basket.
    HTH
    Mar 2003
    ah k, i c.tnx a lot for ur replies.bot alredy d master cable w/ d protective sleeve n an all weather master padlock.gawin ko na sya tom :D
help on securing starex spare tire
