Results 1 to 5 of 5
Threaded View
November 16th, 2010 11:33 AM #1
Hi guys, long time no see! Tagal ako nawala at di ako maka-post dati, ngayon ko lang nasubok ulit.
Would anyone know the location of the ECU of a hyundai starex grx? the casa had just given me a quote (again!) for P1xx,xxx and sad to say pagod na ko kakabayad sa kanila. i have already spent more than 400k for my 2 rides (sta fe and starex grx) and lately the grx's ecu just died. lintek na Ondoy yan, nag-1 year anniversary na dumadale pa din.
intermittent kasi yung problem. sometimes the engine is ok, then suddenly the instrument panel (which is new) suddenly dies, all the gauges's dials fall to zero but the lights on the panel work. the engine will miss-fire on one or more cylinders (most of the time cylinder #4), and of course the tail pipe will smoke. looks to me like a loose/corroded connector or even corroded ic pin. if i can get to the ecu then i can take it to Ramsa or elsewhere. di ko kasi pwede i-byahe ang starex at baka tumirik ako so i need to remove the ecu and bring it to the repair shop.
Can anyone please recommend a shop that can repair an ecu and abs module besides Ramsa. I'm in QC kasi so Ramsa is a bit far from where i am. i heard there is one in Aurora blvd near one of the mrt stations but don't know the name or location of that shop. please post if you know.
thanks to all replies.
A relative of mine in Canada had his Scion FR-S PPF'd and then had it ceramic coated. He says it's...
Ceramic Coating vs PPF (Paint Protection Film)
