Page 96 of 114 FirstFirst ... 46869293949596979899100106 ... LastLast
Results 1,901 to 1,920 of 3622
    Quote Originally Posted by imperialv View Post
    Bastos na mga koreano yang ha.. mayroon pala nyan sa 4x4 variant.. Sa 4x2 wala.. Mayroon automatic door open when shut off.
    Don't fault the Koreans, its actually the local distributor here selecting the options.
    Of course lessening the options, while pegging the same price in Korea = profit for the distributor.
    Jun 2010
    Quote Originally Posted by T|tan View Post
    Inov8, there is an automatic door lock function to choose from to lock on start or lock as it reaches 20kph. This is present in the TOTL PHDM AND KDM unit, not sure if it is present though sa lower models. You may want to check the menu function. I also believe you can turn it off. DocBj helped me to set it to lock during 20kph, mine kasi is in Korean language so kinapa niya in comparison to the way he would choose the option sa TOTL PHDM unit niya. Try to check your vehicle's dash menu system.
    Wala talaga sir.
    Skin kasi dapat standard na un for a car that cost 1.7++M.
    Imagine one time I've been driving for almost an hour in the metro nka UN-LOCK pa pala
    Quote Originally Posted by inov8 View Post
    Wala talaga sir.
    may alternative naman sir, pwede ka bumili aftermarket alarms
    Feb 2013
    Kausap ko yung service adviser kanina tinanung ko kung pwede ba na sa odometer ko basehan yung next pms ko since cgurado ako na di abutin ng 5taw yung odo in 3 months time, sabi nya kelangan talaga ibalik otherwise mavoid warranty ko, pwede ba na mineral nalang gamitin or semi synthetic?
    Posted via Tsikot Mobile App
    Oct 2004
    Quote Originally Posted by ricciboy View Post
    Classic standard answer na talaga ng mga hyundai casa. Tsk tsk tsk. Sabihin mo eh yung bahay at office mo eh magkalapit lang, alangan naman mag long cut ka pa araw araw para lang maabot yung 5k in 3 months nila. Ako yung 5k ko yearly mileage na yun. And i follow the mileage during pms, not the months. Besides, wala naman nakalagay sa service passport na void warranty kung hindi nasunod ang months. Yung nakalagay dun is merely a suggestion or a guide.
    Jan 2014
    Tama yan sir.
    Feb 2013
    Sino ba dito nakapagpalit na ng mags nila? Picture naman.
    Jul 2004
    Hi mga pre,
    May I ask kung saan ok magpa HID ngayon ng sta fe? Medyo pass ako sa retrofit because of the high cost. Ang budget ko kasi nasa mga 10k lang or less. Pasensya na if I really can't backread on all the theads kasi i'm very busy ngayon sa work and hopefully I want to have my HID before holy week.
    Last I remember kasi hindi fit ang mga HID bulbs sa sta fe. You need to have an adapter right? Unless may paraan nang nagawa to have it fit or may nagbebenta na ng adatper.
    Salamat.
    Quote Originally Posted by joms View Post
    Hi mga pre,
    Salamat.
    You can actually DIY as long as you know what type of bulb you are replacing. It is really plug and play. Things you have to consider is cutting the bulb covers, more likely you will be drilling a hole, also knowing where you would position your ballast. You also want to check your regular bulb length vs the hid bulb, also mind the bulb seats if they match well. You don't want the bulb hitting any plastic and it should seat and fit properly in the projectors. I suggest not getting anything higher than 6000k, most effective is between 4700k to 5000k. Anything higher than 6k is too bright and glaring for other motorists, you would not want to blind them on the road. The only difference of getting those retrofits is the type of ballast, bulbs and quality workmanship as they say. Also I believe they will replace your projector lenses to more appropriate ones for its application. Nonetheless, they are experts on what they do.
    Jul 2004
    Thanks but i'd rather have a shop do it. Im not good at DIY
    raquino - thanks for the suggestion. subok naba sila? do you know if there is any branch near the south area? (paranaque/alabang/las pinas)?
    Salamat
    Apr 2006
    Salamat
    Sa Banawe area lang siya. Subok na ito. They have been doing this for several years na. They will show you the proper bulb para tama ang focus. So far sa projector ko maganda ang cut-off.
    Apr 2006
    Hi mga pre,
    Salamat.
    You can check xenonoptics.com also has facebook account. They have good HID's Blitz and Xenon optics brand, very good quality and never had problems with their kits. Get a 4300k for good all around visibility. They will install the right bulb and if an adapter is needed they have it also.
    Feb 2013
    Mga sir confirmed na my pumapasok talaga na daga sa aircon circulation natin tinanggal ko yung filter ko my dumi ng daga problema lng kung saan sya dumadaan sana d nya sirain electrical wirings ko, one more thing yung sa speed indicator yung 30 at 50 talaga bang pula color nya hindi green doubt lng ako, TIAimageuploadedbytsikot-forums1396786530.140552.jpg
    I read that somewhere in the manual. If my memory is correct the red marks indicates the max speed of towing this vehicle on its four wheels. You might want to check again your manual. Sa amin kasi 30 ang red mark, walang 50.
    Jun 2008
    Sir posible bukas ang outside aircon vent (fresh air suction) kaya naka pasok ang maliit na daga (bubuwit) dyan sa cabin filter.
    Feb 2013
    Sorry white pala
    Jan 2013
    Sir ricciboy, maybe meron live mouse living in your car. Suggest put a sticky mat mouse trap at night with some bait. Afaik most cars will not have openings that a rat can enter easily.
    Sent from my GT-I9505 using Tapatalk
    Feb 2013
    Nag umpisa palang sir na gumawa ng bahay nya dahil mga tuyong dahon at damo na kaming nakuha pinatakpan ko pansamantala ng basahan yung butas na posibleng daanan,
    Check ko sir sa manual kung normal nga, sa mga naka 4x2 PHDM AT pakicheck naman kn ganun din sa inyo
    Oct 2004
    Yung mga red marks sa speedo usually speed limits yan sa korea. Sa mga urban places parang 30 ata speed limit dun.
    Feb 2013
    Sir totoo ba yung every 5k na ang pms sa casa wala na yung 3 mnths?
STA FE (Gen 3)
