Page 87 of 114 FirstFirst ... 377783848586878889909197 ... LastLast
Results 1,721 to 1,740 of 3622
    May 2013
    Just brought my SF45 to Hyundai Marcos Highway to have my weather strip replaced. Took them half a day including PMS. I urge all SF45 owners to have your unit checked for leaks.
    Oct 2007
    I checked the bottom of the luggage tray and it's dry even after leaving the car out during the night while it rained, although it's mostly showers, no hard rain. Will bring it to dealer still for them to check especially if there is a need to replace the weatherstrip as a preventive measure.
    By the way, wanted to check, has anyone experienced difficulty driving when it rains - I noticed that with the Sta Fe, there seems to be a delay for the moisture to evaporate after the wipers passes thus having moments where the windshield is not as transparent as I would like it to be. I also noticed that the rain drops on the side windows as well as the rear window takes long to dissipate. I don't have these issues with the CRV or Innova so wondering if it's specific to the glass Hyundai uses? I already shampoo the car including all the windows and the vinegar treatment to no avail. Appreciate any input to help.
    Apr 2011
    Hmm, so far ok naman yung moisture dissipation sakin. Personally I dont think its the glass, it might be the placement of vents or the humidity/airconditioning.
    Oct 2007
    Quote Originally Posted by bjreyesmd View Post
    *bjreyesmd, just to clarify, it's not the fogging of the windows. When it rains and you turn on the wiper, at the moment the wiper passes an area and removes the water, the residue water takes time to dry up (this when even light rain) the effect of which is there is a moment when it seems there is a thin layer of water on the windshield which affects it's transparency.
    On the rain drops for the side/back windows, just noticed it takes time for the rain drops to slide down the glass so combined with the issue in the paragraph above, makes it hard to drive when it rains. I don't have the same issue with Toyota or Honda so wondering if it has something to do with the type of glass/wipers that Hyundai uses.
    Sep 2010
    Quote Originally Posted by practical1 View Post
    Kung hindi sa wiper ang problema nyan ang suggestion ko lang ipa detail mo ang windshield at lahat ng windows ng car mo. There is a residue of "something" in the glass that is why it's like that. Parang ganyan din yung sa ASX ko before at pina detail ko nga and all is well after that. Big Berths or Hillsborough can do that for you.
    Sent from my SGP321 using Tapatalk 4
    Well I think that is normal specially living in the city it might have accumulated a very thin layer of oil film. If you live in an area where there are a lot of vehicles especially trucks and jeepneys, definitely you get oil your windscreen more often. You can clean it with glass compound and apply water repellant. I use the ones below they work very well for me.
    The effect should be that water droplets tend to slide away easily and should only be little. If blotches of water droplets is what you see and sticks to glass it only means it is dirty with oil film, you will also notice that they are not circular small droplets accumulating and sticking to the glass but bigger ones. It is also not an issue with wiper blades unless it is very contaminated with oil or deteriorated rubber blades. Doc Reyes may also be right it must be the Aircon vent positioning.
    Apr 2013
    Sa Mga nag pa install ng DRL kay GaryQ. normal po ba na may konting moisture ang foglights ng Sf3 dahil sa maghapong ulan ngayon?
    Bihira ko po kasing gamitin ang Santa Fe Ko.
    Sep 2010
    Quote Originally Posted by epb888 View Post
    Yes sir. That's normal lang. Ganyan din ang sa car ko but it quickly disappears pag medyo mataas na sikat ng araw.
    Sep 2010
    Ok kaya mods ito sa SF3? http://www.ebay.com/itm/251372193730...84.m1438.l2649
    Apr 2009
    Quote Originally Posted by larry0609 View Post
    If youre refering to the grill, no. 👎 Bka may mas maganda pa dyan.
    Aug 2004
    Ok kaya mods ito sa SF3? 2013 Hyundai Santa FE Hood Bonnet Radiator Tuning Grill | eBay
    BMW style Grille, hehe....
    Jan 2012
    Stock grill is already beautiful.
    This is one makes it look like a copycat...
    Jun 2010
    There are mods na pag pinatulan is as if we're saying nagkamali tyo in buying our unit and should have instead buy other brand -
    IMO, this mods fit the bill.
    BTW, Kelan mo nakuha plate mo sir?
    Sep 2010
    Quote Originally Posted by inov8 View Post
    Thanks for your comments guys!
    A little more than two weeks ago ko nkuha ang plate but still without the sticker.
    Oct 2013
    Question lang po mga sf3 owners. Mavo-void po ba warranty ng sf3 in case na sa labas magpapa-install ng HU...? Plano ko kasi kumuha ng 4x2 unit (HARI). Masyado kasi mahal quotation na nakuha ko galing sa SA ko. 50k for hu, 8k gps and 4k for rear cam. Kung sakaling hindi naman ma-void warranty, baka meron kayong kilalang SA/casa na may best deal. TIA
    Aug 2004
    Quote Originally Posted by dbblazer76 View Post
    sa tatlong Hyundai dealerships napuntahan ko : Hyundai LP; Greenhills (at EDSA); Pasong Tamo ext....puro lahat ganyan bukang bibig nila...pag hindi sa kanila binili...they won't install it, and siempre void ang Warranty... i just find it unreasonably narrow minded on their part.... anyway mukhang madami naman ata satisfied owner's pa install sa reputable shops and mukhang ok naman....no need worry much, go for the mod/upgrade that will make u happy.
    Apr 2011
    I also have Growl HU, ok naman siya for everyday listening. All the controls work including the steering phone buttons which I need for hands free calls. But, since may pagka-audiophile ako, had DSP and amps installed and changed all speakers to aftermarket with subwoofer.
    Oct 2013
    So mga sir, hindi naman ba na-void mga warranty nyo after ng modifications nyo ? Magkano po ba yung alphine, pioneer and growl and saan nyo pinagawa. Many thanks po.
    Check with your casa if it will void the warranty of your headunit, wag naman sana buong warranty ng sasakyan. For the headunit price that depends what model you are looking at, I suggest going to a reputable car audio shop.
    Aug 2010
    Depends on which modifications. The moment you splice or add an additional load (ex. aftermarket amplifier) agad wala na electricals mo. Only the electricals unless may ginawa ka rin sa mga ibang parts.
STA FE (Gen 3)
