The foglamp assembly with integrated DRL I ordered from Exled thru GaryQ just arrived, hehe. The assembly will also be retrofitted with projector HID fogs. Na-excite lang, will post pics once the project is finished.
Exled is the supplier and GaryQ is the authorized installer of Exled here in our country. But he can also order the items from Exled, for you. Here is their link if you are interested in ordering the item yourself
exLED Custom Items :: Hyundai :: Santa Fe DM (2013~) - exLEDSHOP by LEDSTUDiO.Corp.,
Heto naman website ni Gary http://www.hidretrofit.net/V2/
*bjreyesmd, nag text si Gary and he told me dumating na rin daw order ko. Ipasabay ko na siguro pa retrofit ng HL para one time nlang punta ko dun. Nagpa schedule ako this coming Saturday. How about you, kailan schedule mo sa kanya?
Ma alog ang fogs ng santafe natin. Just saying :p
Naka drl po ako pag bumpy road parang nag bliblink yon pala maalog hehe
I see, baka kailangan lang higpitan connections ng drl. Under normal conditions expect may konti alog due to transmission ng vibration frm the diesel engine to the bumper. Kaya may play dapat yung fog assembly to offset this.
*SG, pag nagpalit ako mags, hanapin kita, hehe. So far, satisfied ako sa stock 19s.
Meron na kaya dito sa Tsikoteers nkapagpa HID Retrofit sa Redline Autoworks? Mukhang mas mura compared Kay Garry but not sure of the quality of their work at kun orig mga gamit. Check this link HID Projector Retrofit by Redline Auto Works Philippines - 6800545
Have it checked jun, hindi dapat maalog yan.... sa akin kasi stable..... baka may loose clips lang. BTW, nung kinabit yung DRL mo tinanggal ba buong fog assembly? Baka may screw lang na di nakabit ng maigi nung binalik nila. I just checked mine ngayong gabi with only the foglights on and wala naman ako napansin na vibration ng light on the road. The light should wiggle kung maalog nga ang fog assembly.
Naku, kinabahan tuloy ako ipagalaw yung fog assebly ko, hehe
Share ko lang FC ko yesterday along NLEX and SCETEX. That's 6.6L/100KM, Medyo malabo pics coz phonecam lang at nkapatong sa steering wheel when I took it. Matipid pala at a constant speed of 120kph / 2000RPM
*imperialv, just contact gary thru his website and he will order the items for you.
Yung foglamp assembly with DRL bundled with LED rear bumper lights including install, 18k inabot.
