The Santa Fe isnt actually small, it just looks small based on the design. In fact exteriorly, it has the same dimensions as the previous model. And I think the older gen SF is bigger than the CRV and Escape. Check the dimensions, mas malapad ang SF3.
BTW, the 2nd row slides forward or backward for extra legroom.
Maybe the reason why you said it is smaller exteriorly is because the escape is taller and the CRV is almost the same height. Escape is 1770mm, CRV 1655mm while the SF3 is 1690mm. If you look at the width, SF3 1880mm Escape 1845mm CRV 1820mm, and the length SF3 4690mm Escape 4480mm CRV 4530mm, obviously, the SF3 is larger.
And they never failed us in the aftersales of our Sonata.
