45k pa. Aircon problem and suspension. Plus the no start incidents. Yung abs sensor 1.3k pero 3months pa daw pag iorder. Baka meron ito sa mga suking tindahan.
Grabe naman, only 45K daming sira maybe lemon car nakuha mo.
Sent from my SM-A720F using Tapatalk
Yan disadvantage pag early kumuha ng units. May mga issues na hindi pa natin alam or di pa lumalabas. Just like our TOTL ford everest. 1st customer kami. Transmission broke down 20k pa ang takbo. Good thing may warranty naman.
Sta. Fe namin early rin kami kumuha. First batch. Unang nasira yung headunit. Naayos naman via warranty din.
Pero itong mga issues ngayon sabay2 lumabas. Ang mahal pa naman ng parts.
Help check engine santa fe ko. Tapos ang kupad. Why???
Can't tell, really, since the CEL can mean a lot of things. Literally anything can be going wrong when the CEL lights up. Happened to my Santa Fe once though, and it was the throttle control module. I was not present when they fixed it, so I had no idea what they did, but fortunately it did not require replacement.
Another experience with the CEL was with the Carnival. It would light up every time I depress the accelerator more aggressively than usual, but be gone when I restart the engine. Apparently the fuel filter was overdue for replacement. [emoji28]
Sent from my SM-G900I using Tapatalk
P2112 yung DTC. I cleared the error but bumabalik agad. Sana loose or faulty wiring lang.
Sent from my SM-A605G using Tapatalk
Guys H7 ba highbeam ng 2013 santa fe? How about fog? H11 ba?
Guys favor. Magkaiba ba talaga ang orientation ng high beam ng 2013 santa fe? Pasilip naman if magkaiba yung position ng filaments.
Yung left side nakahiga eh — ganyan yung orientation. Sa right naman \ naka slant.
Need to verify kasi nagpalit ako ng bulbs kaso hindi ko na napansin if ganun talaga orientation niya. Baka kasi mali yung pag kabit ko eh. Now ko lang na encounter hindi same orientation.
Pero level naman yung ilaw pag naka on. Weird lang di ko pa kasi to na encounter
if the throw of the beam and the function are un-impaired, then the installation is probably correct.
i have the same issue with my innova's headlight. just looking at the bulb from the outside, it looks ok. but the throw of the beam is driving me nuts. low beam is fine. but hi beam...!!
hirap kasi buksan... have to remove the air cleaner housing and get lotsa dirt on my hands...
eventually, bubuksan ko rin yan...
in the meantime, low beams muna.
Any idea ano sira sa aircon ng sta fe namin? Tagal lumamig. Parang may nabasa ako common issue daw. Anong part yung ipapatingin?
Sent from my SM-A305GN using Tapatalk
