Page 113 of 114 FirstFirst ... 1363103109110111112113114 LastLast
Results 2,241 to 2,260 of 3622
    Quote Originally Posted by suysuy View Post
    Kamusta dito? Kamusta blowby ninyo? 2013 sta fe may blowbly pag engine oil cap is removed but if oil dipstick lang wala. Wala naman smoke pero naririnig at nafefeel ko yung pressure pag wala yung engine oil cap.
    Nacompare ko kasi sa ford everest namin walang ka hangin2x sa oil cap. Yung sportage at sorento namin may blowby din sa oil cap.
    Sent from my SM-A605G using Tapatalk
    meron na ba OCC?
    Bigla nalang ayaw tumunog ng backup sensors ko. Ano kaya problema?
    check mo kung meron din reversing light... isang switch lng yan. it could be the reversing switch
    Mar 2007
    meron na ba OCC?
    Meron reverse light.
    May alam ba kayong firmware update sa headunit ng sta fe?
    Mar 2007
    Btw sino naka experience dito starting problem? Kanina lang my santa fe wont start. It just kept cranking. Pero on the 2nd try nagstart na.
    Apr 2008
    Glow plugs siguro? Baka due for replacement na.
    Sent from my SM-G900I using Tapatalk
    Mar 2007
    Quote Originally Posted by GTi View Post
    May glow plugs paba ang gen 3? 2013 model. Common issue siya ive seen sa youtube. Baka raw key fob battery issue
    Same kami ng problem sa video na ito.
    Hyundai Santa Fe Starting Problem - YouTube
    Apr 2008
    We used to have the 2011 ReVGT, and I am quite positive that it had glow plugs. Same engine lang naman ito.
    I do wonder though, when he was finally able to start the engine, swabe na siya magstart kahit kapag inulit niya. If it was a key fob issue, shouldn't it have difficulty starting all the time?
    Yes may glow plug parin yan.
    If nagamit na at mainit na engine, hindi na lalabas starting problem mo? If so, glow plug yan.
    Sent from my SM-A720F using Tapatalk
    Mar 2007
    Mas naging frequent yung starting problem ng santa fe namin. 5 times nangyari in just a month. Di ko pa napadala sa casa. Wala bang ibang owners dito naka experience ng ganito?
    Kung glow plugs nga magkano kaya? Pansin ko during rainy days or malamig ang panahon doon lumalabas ang problema. So malamang glow plugs nga? Hmmm
    Mar 2007
    Daming sira. Saan kaya makabili ng backup sensor? Sobrang mahal.
    Apr 2008
    What do suspension parts have to do with hard starting?
    Jan 2008
    Ang mahal naman ng press.. usually 150 pesos lang yan eh
    Feb 2018
    Mga sir pwede po malaman part number ng santa santa fe DM 2015 cabin air filter? Tnx so much
    Oct 2007
    Recently the aircon takes long to cool, I noticed if I rev the engine or if I have a good stretch of free road where I can accelerate the aircon cools faster otherwise if it's traffic and no opportunity to rev, the aircon takes long in cooling. Anybody experience this? Does the Sta Fe aircon really work this way?
    Apr 2008
    Quote Originally Posted by practical1 View Post
    Perhaps it is time for general cleaning?
    Apr 2014
    I think this isn’t unique to the santa fe, happens to some of my cars too. Plus it’s summer time so it will really take a longer time to cool the cabin :D
    Sep 2014
    It’s not normal. Your electric fans are not at optimum revolution. Either or both radiator fan and auxiliary fan may need replacement.
    Kaya nga ayaw ko na sa mga ceossover diesels eh, yan ang handicap niya in the long run aside from the timing belt
    Sa PPVs bukod na sa timing chain, it uses clutch fan at walang degradation ng revolution ng cooling fan sa radiator and aircon kasi lagi naka depende sa engine. Mechanical not electrical
    Croosover diesels should be cheaper than PPVs in that sense, pero ewan ko kumbakit ang mahal nyan Santa Fe ngaun
    Pati aircon problema na after 3-4 years nun car.
    Sep 2013
    If it cools faster if you rev it while on neutral or in traffic, I'll rule out the aux fan and you might have a failing ECV. Might be that the solenoid travel can go only halfway. It adjusts the plate angle of your compressor. Flat if a/c off, halfway on high revs and full angle when on idle or low revs with a/c on. Might be that yours gets stuck on the halfway mark.
    Try mo sa goodgear. Pwede ka pa quote thru email. May mechanic din sila, although wala silang shop aa harap o gilid lang ng shop tatrabahihin.
    Apr 2010
    If your casa allows you to bring parts, mas maganda pang yatang bumili ng lower arm instead of the rubbers then have them pressed. Ang mahal ng machine press nila, saka kasama pa ball joint which you will eventually replace also. Sa Seiring I bought lower arm for less than 5k each, don’t know the price for your model now.
    Pati yung tie rod less than 1k lang sa kanila last time I bought.
    Mar 2007
    Wala naman. Separate job order yan. Dami kasing problema si gen 3 ko. Kaya pina inspect ko na lahat.
    Abs sensor daw yung hard starting sabi ng casa.
STA FE (Gen 3)
