Page 103 of 114 FirstFirst ... 3539399100101102103104105106107113 ... LastLast
Results 2,041 to 2,060 of 3622
    Oct 2013
    Si T|tan you may want to check on 4x4 forums because the 2T may not necessarily work with modern diesel engines like those of the Sta Fe. Most engines 4x4 are those of the Landcruiser, Mitsu 4D56 diesel and other Isuzu engines.
    Posted via Tsikot Mobile App
    Aug 2005
    Just use unioil, i have a starex with DPF, wala siyang black smoke...
    Jul 2006
    I agree with Vic. No need for 2T if your vehicle has a DPF. Our Grand Starex also has DPF, been using Seaoil and Unioil since day 1. DPF doesn't regenerate that much compared to that when you are still using the Big 3's diesel for your KDM SF3 sir T|tan. ACarEnthusiast is also correct. 2T might not work with Hyundai's CRDi engine.
    Thanks for the info guys. I was just wondering its application. I use Unioil anyhow so I do not experience any black smoke.
    Dec 2009
    I use Unioil also (16 months now) and do not experience any black smoke but got curious today on the use of 2T as additive to diesel. Based on the threads I've read below, they say it's applicable to SF3 as well. And lots of testimonials from SFCP members!
    Sir Larry, did you try? I noticed in one of the threads you were curious as well.
    Anyone here who have tried already?
    Here are the discussion threads that I've been back-reading:
    SFCP thread
    Login
    Tsikot thread
    http://tsikot.com/forums/engine-fuel...il-fuel-79879/
    Sep 2010
    Quote Originally Posted by Banong View Post
    SFCP thread
    Login
    Tsikot thread
    Yup, did try it when I still have the SF3. It actually reduces the soot found in the exhaust tip which is very noticeable when I wasn't adding 2T oil. But that was a short test as I eventually sold my SF3. You can try and test it to a diesel car that is spewing black smoke. But if your car is not spewing black smoke then there's really no point in using it, I guess.
    Dec 2009
    Thanks sir Larry. I guess I just have to try it on a friend's montero.
    Sent from my GT-I9505 using Tapatalk
    Jun 2014
    For 1,000 KMS/ 1st month PMS: is it mandatory to have the oil changed already? From previous experience kasi with our ford vehicles, only calibration and tightening of bolts, etc lang ang needed. And it's just usually free.
    But I read here somewhere that dealerships change the oil already during the first month checkup (and therefore, not free).
    Thanks in advanced!
    Quote Originally Posted by TCAS View Post
    Thanks in advanced!
    Yes, it is normal first oil change once you reach 1000km. The idea is similar to breaking in components, in this case your engines moving components will seat or settle properly, ergo small particles of metal shaving will be left in the oil.
    Jan 2014
    While it's the rainy season already with the occasional heavy downpour, I haven't seen any more complaints here about the SF3 leak issue. I hope Hyundai has rectified the defect, albeit no formal public announcement made.
    Oct 2013
    Is it just me or most unit nowadays dont have the stickers from the left rear side portion indicating their Port of Origin? Usually there was this white barcode sticker indicating HARI Batangas. When I picked up our unit last week there was none. Does this mean they are originating somewhere else?
    Jan 2014
    Quote Originally Posted by ACarEnthusiast View Post
    I dropped by Hyundai North EDSA yesterday Sir and saw their for-release units having the sticker. When I got my unit it also had the sticker and at the bottom it said "The label is used for assembly process. Please remove it before delivery."
    Hindi kaya tinanggal lang talaga yung sa'yo para hindi masabihan na "not following instructions"?
    Feb 2013
    Sir please advice ano magandang offset sa rim size na 20x8.5? TIA
    Oct 2013
    Quote Originally Posted by ricciboy View Post
    Try to visit the FB page and Sta fe forum sir. They can provide you more info.
    Sf fb page has info on that, someone has it there. Same exact mags, size and offset that i can only wish I had..
    Oct 2013
    Most likely I didnt know it had that instruction on the sticker. Thank you for the info.
    Feb 2013
    Tried searching several times on FB regarding Sta fe club used different words also nit available, ano ba exact name sa FB? TIA
    Sep 2010
    Use "Santa Fe Club of the Philippines" when joining in FB. You can also join here http://www.santafeclubph.com/forums/ where you can learn a lot about SF3 and other previous models of SF. Send ka PM, here, to imperialv if you want to join the latter.
    Feb 2013
    Sir paki approved naman request ko sa SFCP on FB
    Sep 2010
    Calling Pres Vic...hehe!
STA FE (Gen 3)
