Results 1 to 20 of 58
    Oct 2009
    kanina nagpa change oil ako sa casa then ang inilagay nakita ko is Shell Helix Plus hindi yung Shell Helix Diesel Plus, ok lang kaya ito? CRDi pala Tucson ko po.
    imbis na ito..
    ito ang nilagay sa casa...
    sabi ng mekaniko nung tinanong ko sya is OK lang daw sabi nya?
    compatible kaya talaga itong Shell Helix Plus (for Gas) sa CRDi engine?
    any inputs guys?
    Pre...check mo kung may CI-4 yung nilagay nilang langis...May specifications
    kasi yung mga langis na yan yung iba pwede sa diesel at gas basta it
    meets or exceeds the type of specifications that you need...Sa ngayon
    CI-4 yung specifications para sa mga turbocharged diesel engines...Pag
    walang nakalagay na ganun eh mas magandang ibalik mo sa kanila baka
    hindi nila alam yan...
    Oct 2009
    hi Eric, i checked Shell website wala yung CI-4 na sinasabi mo.
    Ill check with the shell gas station mismo to check the label din.
    Hi Harold,
    I did some searching about Shell Helix Plus and Shell Diesel helix Plus and
    both of those oils were rates as SL/CF and CF respectively. API CF ratings
    are:
    Introduced in 1994. For off-road, indirect-injected and other diesel
    engines including those using fuel with over 0.5% weight sulfur. Can be
    used in place of CD oils.
    So I guess you better search for other oils that will meet those "Direct
    Injected" and "Turbocharged" specifications for your CRDI engine...
    Apr 2005
    API CF is obsolete for your eVGT CRDi engine
    It should be CI or CJ. Fully synthetic is highly recommended
    Quote Originally Posted by trackers888 View Post
    Hi Tracker...
    Are you referring to CJ-4?
    Anong oil nga pala yung may ganitong API rating?
    *TS: Better change your oil to the recommended rated oil CI-4...
    CF are not designed for direct injected and turbocharged engine...
    Although you can continue using it...wala pa naman magiging problem engine
    mo kasi bago pa yan...Hintay ka na lang ng ilang taon at dyan ka magsisisi.
    Naka Gen. 1 CRDi si harold.
    CRDi with normal turbo. Not yet the R series engine.
    Oct 2009
    Quote Originally Posted by erick_214 View Post
    Hi Harold,
    are:
    problem is, Hyundai pasig doesnt allow customer to bring in their oil.
    they only use Shell oils
    Quote Originally Posted by harold13 View Post
    imbis na ito..
    any inputs guys?
    I i were you di ko tatanggapin yan . Sometimes ganyan casa, makabenta lang lahat gagawin There are other casa that allows customer's preferred oil, pwede ka pa PMS aside sa kinuhanan mong dealer.
    Apr 2005
    Sa owners manual naka specify ang oil API rate at grade, they should follow it dahil sila ang CASA!
    Kung hindi mag met ang stock oil nila dapat payagan kang mag dala ng sarili mong oil!
    Ganito gawa ko sa unit ko, I look for thier oil muna at kapag hindi as per owners manual, hindi ako pumapayag.
    CRDi repair is VERY VERY expensive at ang problem hindi pa yan lalabas ngayon... maybe after your warranty period...
Shell Helix Plus on a Tucson CRDi engine? pwede din daw?
