Results 1 to 4 of 4
- Apr 2010
- 130
September 24th, 2019 10:48 AM #1Anybody who knows where I can have the switch repaired? After almost 10 years, nagloloko na yung a/c switch ng Santa Fe ko. Pag ON ng A/C switch or todo cold yung rotary selector, hot exhaust yung lumalabas. Kaya namang marecover yung normal operation like always switching the A/C switch on and not putting rotary to full cold, nuisance lang. Replacement of the module is a bit expensive.
Minicarph saan ka ulit nagpapagawa? TIA.
- Jan 2008
- 4,726
September 24th, 2019 11:39 AM #2
- Apr 2010
- 130
September 25th, 2019 10:41 PM #3
- Apr 2010
- 130
October 12th, 2019 05:24 PM #4after loosening crash pad lower panel, removing center lower garnish and loosening center fascia panel. was able to remove aircon control unit. disassembled control assembly by removing 4 phillips screws and loosening the tabs, sprayed contact cleaner on the control contact points and switches are now working. ingat lang sa pagbalik ng center lower garnish because the ash tray is connected to the garnish through 4 narrow plastic protrusions sa santa fe gen 2.5.
suggestion. you might try the local sarplas shops. the items will probably be painted in the color...
