Zic Up ok din na oil.
Got a closer look at the HGMO oil, it is manufactured in Florida by Amalie Oil Company for Hyundai Philippines. Its classification is SN/CF and ACEA B4 with SAE 5W-40.
Kung ACEA B4 pasok sa CRDi pero yung CF rating sabit tayo dyan..
Sent from my LT26i using Tapatalk 2
Yup, ang label niya is for all types of engines (whether gas or diesel). The API (American standard) rating for diesel is CF but it also passes the requirements for ACEA B4 (European standard). Yun ang nakalagay sa label. Made in USA for Hyundai Philippines kaya siguro mahal.....hehehe
Anyway, also checked Amalie Oil Company.... oill manufacturer sila since 1903, but this is the first time I have heard of them
Motul parin ako
Pero in fairness ha, I tried HGMO FS oil sa 50,000km PMS nung 2010 SF eVGT namin, so far so good. 54K na odo ngayon.
bukas 15k pms tucson ko, subukan ko mutol crdi diesel sae 5w-40. api:SN... hindi po CF rating ang equivalent SN. eto ( It is possible for an oil to conform to both the gasoline and diesel standards. In fact, it is the norm for all diesel rated engine oils to carry the "corresponding" gasoline specification. For example, API CJ-4 will almost always list either SL or SM, API CI-4 with SL, API CH-4 with SJ, and so on.) magkano kaya charge sa 15k pms.
Is there a link to your statement? I've seen quite a few SL or SM oils if used in gasoline engines, but only CF when used in diesels.
- - - Updated - - -
Sa Seiring Araneta Avenue may Kixx Turbo RV. Di ako sure kung saan nakakahanap ng Zic e'
Yung Top1 parang "pilit" na synthetic blend oil lang daw yun. Tsaka okay yun Kixx kasi sa Korea din mismo ginagawa yun oil, pasok sa requirement ng R engine.
- - - Updated - - -
marketing term yung synthetic hehe
unless 100% synthetic nakalagay, semi synthetic na yan. yung mga fully synthetic marketing term din lang. semi syn lang yun.
yung Zic, korean made din. and naka lagay na sila yung largest semi-synthetic or group3 base oil manufacturer sa mundo. ito gamit ko ngayon.
For 1000kms oil change ano po marerecommend nyong oil and mineral, semi or fully syn for my r engine(sportage)
May nakagamit na ba sa inyo ng Kixx D1?
Mas ok ba sya kesa sa Kixx Turbo?
Thanks in advance!
which kixx d1 and turbo? iba ibang variety yan..
