Results 1 to 2 of 2
- May 2011
- 108
June 23rd, 2013 04:12 PM #1Hi guys, I just changed my Tucson ix35 car battery today from the stock to Motolite 2SM Excel.
Now Im not sure if its related or coincidence but it only lit up after I changed my car's battery.
Should I be worried? Should I send it off to hyundai for checkup?
- Apr 2006
- 351
June 23rd, 2013 06:30 PM #2Try to reset your ecu. Usually after batteries are changed, the ecu should be reset. Turn your key to on position for 10-15 seconds then back to off postion. do this 3 times then remove key then start car. If this doesn't do the trick then have an OBD check.
I think THAT may very well be one of the likely reasons. It's quite evident that the cooling...
