Results 981 to 990 of 1692
- Jun 2008
- 1,741
November 19th, 2010 10:51 AM #981
November 19th, 2010 11:02 AM #982
- Aug 2004
- 184
November 19th, 2010 03:21 PM #983
- Apr 2010
- 321
November 19th, 2010 07:56 PM #984Sa ibang cars na nakikita ko na may small dents like that...nilalagyan na lang ng sticker na parang bullet hole from a gunshot.
Pero yung mga seasoned na pintor...kaya gawan ng paraan yan.
- Jan 2010
- 52
January 6th, 2011 11:51 PM #985Hi Folks -
Wanted to check if anyone experience a faulty headlight switch? Mine seems to be defective as the light won't go on without me toggling it. Hassle kasi delikado sa gabi when you use signals / change to bright it suddenly goes off.
Could understand the factory defect but am not too happy with the service being provided. Brought it December to a service center and up till now wala lang mang update or estimate when parts will come / what the plan is.
rpp
January 10th, 2011 11:57 PM #986
May nakaranas na sa inyo kung nakapark. then pag aatras ka i-lalagay sa R. hindi umaatras, you have to step on gas para mag move yung car to reverse? then may KRRUG!! na sound na malakas. parang may naipit e. saan kaya galing yun?
January 11th, 2011 12:04 AM #987
Kapag matagal na di nagamit. Minsan nagkaka ganyan.
Sa Hand brake ata yan, harold.
January 11th, 2011 06:54 AM #988
yun din suspecha ko e.
its either dati nung medyo nakapark ng 3 days or pag bagong car wash then natuyuan ng tubig.( ako lang kasi naglilinis ng sasakyan ko).
or sa handbrake nung sinikipan, 2 clicks lang masikip na yung handbrake. papa adjust ko na lang sa next PMS.
try ko ifullhandbrake hanggang 3 clicks, para everytme gagamitin hindi nag ststuck.mas delikado ata kung hindi ko ginamit hand brake pag nag papark ako sa bahay?
January 11th, 2011 10:32 AM #989
most probably nangyayari yan kapag nabasa ang rotor plate pag bagong car wash or galing sa ulan tapos nag-park ka na sa isang dry na lugar.. AFAIK, nagka-karoon ng oxidation (mild rust) sa ibabaw ng rotor plate at the same time natutuyo na ang mga brake pads at nagkakaroon ng adhesion.. ang ginagawa ko kapag sa ganitong situation hindi na ako nag-footbrake instead ay naka Park mode lang tapos kinakalsuhan ko na lang ang mga gulong...
January 11th, 2011 11:08 AM #990
pwede din yan. or siguro after ko mag car wash, iikot ko muna ng 1 round sa village yung auto para matuyo at uminit yung brakes ko bago ko ipirme sa parking.
may kinalaman kaya ito sa pagiging masikip ang handbrake? ngayon kasi 2 clicks lang masikip na. usually sabi 3 clicks daw dapat.
thanks for the insights. binilhan ko kasi ng t-10 led bulbs iyong mirage nila for its park...
2013 Mitsubishi Mirage
