Page 12 of 12 FirstFirst ... 289101112
Results 221 to 240 of 1692
    Jun 2008
    Quote Originally Posted by pepengkulisap View Post
    Permission to post sir
    Mga s
    Tanong kolang kung meron na sa inyo nagpalit ng fuel filter during the 80kpms of GLS Matic na gasoline model?
    Medyo na confuse kasi ako sa 2 casa na hiningan ko ng quotation, ung isa nakalagay palit fuel filter, ung isa naman wala. So dun ako nagpa pms sa mas mura na wala palit fuel filter. Nung tinanong ko ang sabi sakin ay di daw pinapalitan un kasi gas daw unit ko at maintenance free daw.
    Any comment po mga sir??
    Ang fuel filter nasa loob ng tanke kasama ng fuel pump kaya sabi di pinapalitan. 80k kms pwede na yan e check /cleaning /replace depende sa actual condition pag nabuksan.
    Sent from my NX549J using Tsikot Forums mobile app
    Apr 2009
    Guys patulong naman. 2010 diesel Revgt ang ride. Ano kaya caused ng engine stalling? First time na nangyari bigla na lang namatay makina ng tucson ko. Malakas ang battery, madaming krudo. Puro redondo lang. Pina tow ko na sa Hyundai Pasig. Bukas na lang daw nila ako iinform kung ano possible cause at busy daw sila. Kindly give me some inputs based on your experience kung meron man please. Mas maganda syempre kung may idea ako para iwas "taga" ng casa
    Nov 2007
    Dont have an answer but talagang matagal sa hyundai pasig magdiagnose at sobrang puno sila parati. But i can confirm na sobrang mahal ng parts nila and even diagnostic fee nila. Just in case u need a 2nd opinion, i suggest bringing your car to SL auto service at the other end of C5, libis side fronting eastwood para makamura ka. Korean owner and head mechanic doon
    Apr 2009
    Quote Originally Posted by JJB View Post
    Thank you for the input. Broken fuel pump daw ang problema ng tucson ko. Kaya lang wala daw pyesa. San kaya may pyesa? and kung sakali ok lang ba kung ipa tow ko out of the casa and auto ko at dalhin sa ibang talyer?
    Dec 2009
    ^There is a hose underneath the passenger side to drain rain water
    Clog it and rain water will accumulate
    Clogging happens when the owner habitually raise the wiper from the windshield
    Sent from my GT-P3110 using Tsikot Forums mobile app
    Jan 2009
    Hi guys,
    Nagpalit ako ng break pads (original from fronte) sa 2014 Tucson crdi ko. Pansin ko maingay when I'm doing full stop and when I slowly releasing it from full stop. Yung ingay nya parang ugong e. May idea kayo kung baket?
    Sent from my HUAWEI M2-801L using Tsikot Forums mobile app
    Nov 2007
    Quote Originally Posted by red.speedy View Post
    Hi guys,
    May ugong talaga ang original brake pads ng tucson. You shouldve used aftermarket or pads for kia sportage para walang ingay
    Jan 2009
    Thanks! Nagtataka lang ako kasi yung pads which came with the unit wala namang ganung ingay. Anyway, pag napudpod to palitan ko na lang ng pang kia sportage.
    Jan 2009
    Di ko na matiis ang ingay so pinalitan ko na ng Bendix General CT. Issue fixed.
    Apr 2010
    Hi,
    My 2010 Tucson now has very prominent shift problem - cannot shift from N to R and P to R. I read from the forum, it's defective inhibitor switch, as I check my break light it's working. I check with Fronte, the inhibitor switch costs 4k + labor (from freelance electrician).
    Does anyone have experience replacing inhibitor switch outside casa? Meron kaya better replacement na hindi mabilis masira?
    Kindly share your experience and feedback.
    When my unit is still under warranty, I experience intermittent behavior of this problem, I complain several time sa casa about it. They told me they update the ECU, the switch are working fine. Kainis, ngayon lang naging prominent.
    Thanks in advance.
    yes... di naman hassle sa hyundai dasmarinas. at may spare agad sila during that time...
    Sent from my SM-N950F using Tsikot Forums mobile app
    Nov 2007
    Mahal pala ng inhibitor switch at 4k, wala pang labor. Mine was changed a few years ago under warranty but it's acting up again
    Sep 2019
    Nag testdrive ako ng 2010 Tucson A/T kanina. It was all good sa slow traffic pero nung may mga 200 meters na bakante at inapakan ko yung gas to overtake, medyo malakas yung engine sound. I'm a new driver kaya hindi ko talaga ma compare pero feel ko lang na malakas yung sound pumapasok talaga sa loob ng cabin. Tanong ko lang kung ganun ba talaga or is it a possible symptom of an underlying problem.
    Salamat po sa sasagot.
    Yan ang symptoms ng mataas na fuel consumption. Ang payo ko sa iyo. Wag mo upakan ang accelerator. Tahimik pa ang iyong pagdrive.
    Normal lang po yan.
    Apr 2009
    Sa mga expert dyan. Help naman. Yung 2nd gen Revgt is diesel tucson ko with 102k mileage ayaw humatak. Limited ang rpm nya until 2.5k lang. Compared noon na madalas ko sya e revline sa 4.3k. Sudden ang onset ng issue. While crusing sa slex napansin ko na lang na ayaw na humataw tapos lumabas ang CEL. Dinala ko sa Goodgear pasay kanina. Ayon sa scanner nila Turbocharger daw ang may fault. binaba and nilinis nila ang turbine, nilinis ang egr, maf sensor, replaced ang turbo actuator. Pero ganun pa din. Iniwan ko na lang at nagcommute pauwi. Any inputs on what else to check guys. Tantya ko sa mga mekaniko hilo na e.
    Quote Originally Posted by poknet View Post
    How about the fuel filter, air filter?
Issues sa Tucson 2010
