Haist kabagobago lng nagas gasan kaagad haistttt . Nakakawalang ganang magdrive
Mga sir, bago lang po ako dito. Plan ko kasi bumili ng 2nd hand tucson (2011). And sa mga nabasa ko marami daw issues (electrical and namamatayan makina). Pero not sure kung sa 2011 ito. Wala kasi akong kakilala talaga na meron tucson 2011 kaya wala ako matanungan. Baka may idea kayo kung okay ba ang tucson na ito. Pang second hand lang kasi budget ko. Salamat po
2011 HYUNDAI TUCSON THETA II 2.0 GAS 4X2 AUTOMATIC
Mileage: 14,000kms
Ginasgasan nila naiinggit siguro. Napansin ko lang nung nakauwi na aq tskkk
Sakit tlga bro. Hnd ko pa sinubukan try ko palang hehe.tucson din ba sau bro
Hi all. Need a little help lang. May nakaexperience na ba sa inyo an issue with central locking na parang nag lock/unlock sound siya when it shouldnt? when i lock all doors from driver control, then open ko yung door, dun yung sound (3x na parang naglalock/unlock) tapos hindi rin maoopen ang boot/cargo door kahit iunlock ko na with the key. nawawala lang naman on its own after a little while and no other problems with unlock/locking. it's been happening intermittently for a week now, though there are days that it doesnt happen. a little over a year pa lang tucson crdi ko. covered ba ito sa warranty?
thanks for any response. God bless.![]()
Remove negative terminal from battery. Leave alone for about 5 minutes. Then ikabit mo na. That is hard re-set, this procedure should clear any minor faults stored in your ecu. But major trouble codes would need to be cleared by the dealer. Of course pag may major trouble code, meron sira yan which the dealer would troubleshoot for you.
__________________________________________________ _______________________________
Was fiddling with the trip meter this morning, and found out my fuel mileage ....... 11.5 kms per litre.
Considering that our Vios gets 12 kms/litre on average, that is not bad .........
Not bad at all ...![]()
Was anybody here experienced unintentional acceleration of your unit either on braking or slowly moving to a parking area?
Happens number of times to me, actually doesn't matter if AC is on or off. What do you think is the culprit? Tried resetting the ecu by taking out neg battery terminal but still rpm rev up without touching the accelerator pedal parang humahatak pa rin kahit brake's applied already.
Tucson unit 09model auto trans and 48k odo reading.
Thanks in advance!
Tucson boys, has anyone of you tried this?
Diesel Tuning Philippines > Diesel Chip Tuning and Performance Tuning Box Philippines
The Tucson is fast out of the box, but .........![]()
