Results 1 to 3 of 3
- Aug 2004
- 184
April 6th, 2013 04:27 PM #1Hi,
May nakapag pa palit na ba sa inyo ng in tank fuel filter ng Hyundai Tucson 2010 outside casa?
May special tool kasi kailangan to open (Fuel Pump Plate Cover Remover Installer)
Eto ata yong special tool...
https://hyundai.spx.com/detail.aspx?t=106
If meron na, pa share naman, where and how much.
TIA
April 8th, 2013 09:43 AM #2
i dont think you need a special tool for this...a good old sandpaper with a steady grip will do or if mahigpit talaga, yung generic oil filter remover na chain type or rope and steel rod which i usually use is ever reliable...Try to inquire with your local gasoline station to clarify...
BANNED BANNED BANNED
- Mar 2013
- 73
April 9th, 2013 06:26 AM #3Simple lang yan ah, thr hyundai fuel filter is just about the same diameter as the hyundai oil filters, baka pede na yun
high idle RPM at engine start
