my latest mod...actually first modification
teaser pix muna
na kay garyq ang output pix, paki antay post niya sa thread niya sa car lights and lamp talk....bow ako sa skills at linis mag trabaho ni sir garyq![]()
*Kent= sir... yung hi beam lang ba ang pinalitan or pati yung stock low beam projector na frosted pinalitan din?
paki pm po si sir garyq sa cost, hindi pa kasi tapos yung project. pati kasi fogs pina retrofit ko din...mounted na pero wala pang shroud at baka mag fabricate pa siya ng acrylic cover. pero working na lahat...to be continued next week ang project kasi mag short vacation ako this weekend![]()
* jpg & capt bob - pinalitan din ang stock halogen projector, bukod sa frosted makitid ang bowl design kaya limited lang talaga output non. bixenon pareho ang quad projectors, pati pala fog lights ko bixenon din kasi naubusan ng stock si garyq ng pang fogs
last night lang natapos yung project, 1am na naka alis sa amin si sir gary, balik pa siya next week para sa shroud ng fogs![]()
Nice upgrade Sir Kent!
I suggest yung inalis na projector lens (HL Low) sa fog mo nalang ipalagay
congrats kent on your upgrade ang ganda. kaso mukhang mahal yung upgrade na ito...
patira mo na ang tucson mo SG, bagay dyan fxr 55 watts...baka maunahan ka pa ng utol ko
ok talaga ang retrofit, ganda ng cut off at kahit tumayo ka sa harap ng auto hindi ka masisilaw![]()
First of all I would like to thank Kent1023 for trusting me with his black beauty, hehe. Bro inspired ako coz of the crispy pata, hahahaha. Seriously, guys like you really make my work very enjoyable
Anyways to answer some questions:
The outer halogen projector was replaced with a bixenon hid projector with Philips bulbs, driven by matsushita oem ballasts. I was really suprised when I opened the HL. The design of the outer stock projector is one of the weirdest I've seen. From the design of the bowl and the body, you will not be suprised that the output is crappy at best. It was a pain.... to mount the hid projector.
The inner reflector bowl was replaced with a bixenon hid projector with philips bulbs, driven by Denso oem ballasts.
One of the hardest setup I did coz of the space limitations. BTW, maganda wiring routing ng Hyundai and the stock harness. As always nothing was cut sa oem harness and I installed a separate circuit for all 6 ballasts! 6 fuses, 6 relays, 3 on each side.
The fogs were retrofitted with d2s bixenon projectors na sealed type,same as the balck everest I did. Coz of the height, the output is nice and can even pass for a headlight output. Mas malakas pa nga raw output nito vs the stock halogen, hehe. Hindi pde gamitin yung halogen projectors for the fogs.
All bulbs are 4300k. Need to make shrouds for the fogs and install white LEDS for the parklight.
Some pix:
output LO, quad
output HI, quad.
and of course the most important, output sa road:
The cam is not in AWB and I tried to make very close to what the eyes can see pero lumalabas maputi talaga coz of the intensity especially sa gitna.
Better to see in person, haha.
The tint which I believe is medium dark will reduce the output pero not so much coz naka quad naman. The main hl may flicker na blue and the fogs, purple. No glare on top of the cutoff.
PM me na lang for an estimate.
the fuse box and the relays are mounted rigidly, same as with all the 6 ballasts.
Galing naman Sir Gary.... Ako ata ang may kailangan magpa ganyan na ilaw sa inyo since malayo na po ang byahe ko lagi... Saka ang hirap talaga sa diabetic eh unpredictable eyesight.
Kindly PM me naman po the price para naman po mapag-ipunan ko at mapaayos ko po sa inyo.
Thanks po Sir Gary....
