Page 31 of 44 FirstFirst ... 2127282930313233343541 ... LastLast
Results 601 to 620 of 1696
    Apr 2015
    Guys hingi lng ako ng suggestions. Naglagay ako ng isang 12inch subwoofer s koche ko, mlkas sya bumayo tska mgnda tunog nya ksi sealed ung baffle ko. Ngaun, may mga nginig or garalgal na tumutunog s trunk or back seat pg mlkas n ung sound. Ano kya dpt gawin or ilagay? Hyundai accent 2014 sedan low end ung koche ko. Thanks!
    Quote Originally Posted by cmacgm View Post
    Hello klangan na bang ireplace spark plug 10k kms tucson ? Nirerecommend kasi sakin ng advisor pero pinacancel ko sana di ako nagkamali. Ok na ba yung 7600 pesos for 10k pms? Yun ang bigay sakin. Quezon ave nga pala yu g casa ty
    sparkplugs at 10k? bullshit.
    Dont be fooled by this SA. First reason is that its not even scheduled at 10k. And its inspect and replace. Not replace because SA tells you so. Join the service personel who will remove and inspect the spark plug. Im for sure it will be like brand new.
    Feb 2014
    Just found this. Hyundai USA recommended maintenance schedule with details. Pwede siguro ito gawing guide.
    https://www.hyundaiusa.com/maintenance-schedule/
    Sa susunod parang gusto ko bantayan yung work na gingawa nila. Inspect muna bago replace.
    55K is coming fast and looking at not having it done sa casa. Di ko naman na nasusulit warranty. Gina-grasahan lang lagi ang piyesa pag may tumutunog tapos after 2 weeks lagatok ulit hanggang sa nauwi na lang na sa labas ko rin pinagawa. At the expense of 3x the maintenance price for the hope na ma-cover ng warranty yung defect na di rin naman tama ang pag-address regardless kahit saang casa ko pa dalhin, might as well take my business elsewhere.
    Any recommendation sa Paranaque / Makati area na gas / service station na maalam na mag-service ng Hyundai vehicles? Accent RB na gas nga pala 'to. Ideally may matatambayan habang nag-aantay para makatrabaho pa. TIA!
    not even 10days, 45k maintenance na.
    1. brake maintenance: rear pads worn out cost 2800php. not satisfied with tech response. ill get another tech for brake maintenance. (keeping the old brake pads for reference). mushy feel now but strong stopping power. ill need to brake-it in(pun-intended)
    2.tire rotation as per my instruction. they missed this. front left and right were worn out more but evenly. noisy ride now lol. I may need wheel balancing.
    3. atf change 4lit for 2400php. opted for this. SA ask 45k or 65k. of course I want to keep this car extra clean. atf drain looks reddish. process is not dialysis. they drain fill and bleed/level. they bleed/level by running at creep while car is lifted. upshift and downshift feels smoother.
    4. engine oil drain looks amber'ish. quite happy with fully synth oil.
    5. Sparkplugs are scheduled at 60k. I wanted to see them. iridium plugs. still good.
    6. Engine bay spray with high pressure water then dried off with pressurized air. then some antirust spray. not needed too bad I didnt catch it. its only 240php though.
    7. Cabin filter cleaned. not even replaced. im not complaining.
    8. injector cleaning as per my request. 3000php 15minutes. fuel line replace with tank with some cleaner. is this the normal practice? nasty exhaust fumes.
    9. air filter cleaned. I insisted on a new one. 600php. engine feels new.
    *glad they allow me to inspect the car with the tech. and take pictures too hahaha(shutter sound muted)
    Jul 2015
    sir which casa? i was not allowed to go near my car during tune up in hyundai pasig. hech we didn't even get empty bottles of the oil they used.
    Just had my 50k pms. Minor pms plus oil change. I requested for underbody nuts and bolts retightening. Thank goodness my SA was back.
    Doing 140kph sweeping turns are quite smoother now.
    Vehicle is now at 51200 kms. Prepping for 55k major pms lol.
    Quote Originally Posted by batang_raon14 View Post
    For accent owners: Hyundai Accent owners manuals, user guides, repair, service manuals
    all the info you need for servicing your vehicle. You can print and show to your favorite mechanic para mabilis gawa.
    For elantra owners: hemanual.org
    Uy, ayos 'to! Thanks bro! So for 55K, I assume ito yung kailangan:
    30,000 miles (48,000 km) or 24 months
    ❑ Rotate tires
    ❑ Inspect battery condition
    ❑ Inspect vacuum hose
    ❑ Inspect air conditioning refrigerant
    ❑ Inspect brake hoses and lines
    ❑ Inspect drive shafts and boots
    ❑ Inspect exhaust pipe and muffler
    ❑ Inspect front brake disc/pads, calipers
    ❑ Inspect rear brake disc/pads (if equipped)
    ❑ Inspect rear brake drums/linings (if equipped)
    ❑ Inspect steering gear box, linkage & boots/lower arm ball joint, upper arm ball joint
    ❑ Inspect suspension mounting bolts
    ❑ Inspect brake/clutch (if equipped) fluid
    ❑ Inspect fuel filter *2
    ❑ Inspect fuel lines, fuel hoses and connections
    ❑ Inspect fuel tank air filter (if equipped) *2
    ❑ Inspect parking brake
    ❑ Inspect vapor hose and fuel filler cap
    ❑ Replace climate control air filter (for evaporator and blower unit)
    ❑ Replace air cleaner filter
    ❑ Replace engine oil and filter (30,000 miles (48,000 km) or 48 months)
    ❑ Add fuel additive *1 (30,000 miles (48,000 km) or 48 months)
    I would suggest following severe usage maintenance of
    every 7500kms for the oil change fully synthetic oil. I would do brake inspection every 7500km also.
    For the mechanical...its really up to you. Casa or outside. Meron naman documents. There are two versions the long(every 15k or 10k depend sa location) and the short(every 7500 or 5000).
    If you have pending underchasis issues. Gawin na immediately yun mechanical tightening. mainly, the front and rear suspension and the steering asembly.
    Hyundai Accent: Maintenance under severe usage conditions - Scheduled maintenance service - Maintenance - Hyundai Accent 2010-2015 Owners Manual
    Jun 2015
    Good day guys. Newbie here. Ill have my 1st PMS on Saturday. Sa Hyundai North Edsa ko sya balak dalhin. Anything special that I need to do beforehand? Some preparations perhaps?
    My Accent Hatchback 1.6 VGT just turned 1 year old last May 27 having about 8,500 kms and do PMS outside casa. Previous oil used - HGMO Fully Synthetic.
    *rotate tires
    *brake cleaned
    *air filter cleaned
    *engine oil and oil filter changed
    Breakdowns:
    6L oil Fully Synthetic (Total PickUp 9200 First Gold 5w30) = Php 2,820
    Oil Filter (casa oil filter) = Php 650
    Labor cost + Php 100 tip = Php 725
    TOTAL = Php 4,195
    Apr 2011
    Quote Originally Posted by andrewnathaniel View Post
    *rotate tires
    *brake cleaned
    *air filter cleaned
    Breakdowns:
    TOTAL = Php 4,195
    Very liberating noh. Gusto ko rin sana pagawa sa labas ayaw ni kumander. Hehe
    Feb 2005
    Hyundai QAve quoted 10k PMS for Elantra - Php 11,622.00
    Engine Wash, Spark Plug, semi-Synthetic oil, Wheel alligning, Oil filter.
    Tataas at tataas pa yan paps. If hayaan mo lang sila ang mag-decide kung anong gagawin sa PMS ng sasakyan mo aabot talaga ng ganyan. Naglalaro na nga lagi recently between 6-18K ang PMS sa HARI. Partida Hyundai Accent na gas lang yung akin. In a way sa aftersales talaga sila bumabawi. Huwag ka na rin umasa for warranty, as mentioned in my post in other threads, kung kayang madaan sa lubrication ng parts, ilu-lubricate lang para mawala yung nire-raise mong problema. Just my .02.
    Quote Originally Posted by strayWOLF View Post
    Woah?! Sobrang mahal naman nyan, tapos palit na talaga agad ng spark plug sa 10k kms? Try to check your manual, kung talagang sa 10k kms eh dapat na gawin yung inooffer nila.
    Jun 2015
    That is insane.
    Can you post the breakdown?
    Sep 2014
    For a gasoline engine? Twak talaga lol
    60k pms done yesterday.
    Aside from the usual maintenance. Fuel filter change was added and spark plug change. Fuel filter (1800 pesos)was full of black sediments. I will change again at 90k and 120k.
    Spark plugs are ngk iridiums. 2800 pesos
    Old spark plugs were looking bad. Next change at 100k
    After maintenance car acceleration was noticeably peppy.
    Apr 2012
    Every ilang kms spark plug change ng Hyundai?
Hyundai PMS
