Guyz & galz, ask ko lang poh ang idling speed ng accent diesel manual transmission? Nasa normal range ba ang above 750 RPM o dapat ay mas mababa (with fuel consumption in mind). Also, rev matching ba ang feature ng diesel engine na pag foot off the gas pedal pero tumataas ang rev nya hanggang 1200 RPM right after depressing the clutch whilst shifted to a higher gear? Tnx
when you depress the clutch, the load on the engine is removed, and that engine responds by upping its rpm temporarily.
i do not know the normal idling rpm, but it should be in the owner's manual. if not, it can be googled, po.
we also used to sagad our idling rpms in our non-computerized cars, to save fuel. we were dependent on very meager resources then (allowance!). problems arise because the idling become rough, battery charging is compromised, and the engine dies when the aircon is turned on. but tinkering with the car was fun.
Tnx for the info guyz, curious lang kz ako dahil hindi ko na magamit ang engine brake & laging babad sa clutch pedal ang driving norm ko ngyon. Pagbumaba ang vehicle speed whilst in a higher gear than normal ay lalong bumibilis ang vehicle speed & ung engine ay mas lalong tataas ang engine RPM up to about 1k to 1200 RPM for about 5 seconds before settling down to about 800 RPM. If the driver will just step on the brake pedal to decelerate without depressing the clutch pedal for engine brake purposes then the engine's torque will overpower the foot brake being applied which may lead to an uncontrollable car behavior. Hope everyone gets what I'm describing. Tnx again.
mga sir kapag full tank automatic mga ilang liters kaya? or yun na yung nasa tank capacity nya sa specs na 43L?
Sent from my MI 3W using Tapatalk
Hi may nag pa egr blanking na ba sainyo?
Meron po ba sa inyo nagpa-install ng turbo timer? Saan at magkano po magpa-install?
Sent from my EVA-L19 using Tapatalk
What is the average pms cost for the current accent hatch with dct ?
mga sir may nakapag try na po ba sa inyo mag add ng 2T sa fuel? nabasa ko sa other tsikot forums less than 1800 bar rail pressure ok gamitin ang 2T, nakita ko sa specs 1300 bar ang rail pressure ng accent crdi.
Sent from my MI 3W using Tsikot Forums mobile app
mga sir ask ko lang po. how much yung 20k pms? yung casa where i have my pms parang ang mahal kasi ng price nila.
may dpf ba 2013 model?
sa manual kasi. engine oil requirement is acea-c3 pag may dpf. pag wala acea-b4
Sent from my SM-A9100 using Tapatalk
Hi. Considering buying an accent to service my parents with a driver, due to fuel efficiency. Driver driven naman.
Has to be diesel and has to be an automatic so my dad can drive it during weekends without the driver.
Is a 2014 2nd hand car a good buy? Should i look out for anything for repair?
Thanks.
Just change the fuel filter(very important). Do an engine decarb. Watch the lower arm bushing. My mechanic says they have to replace the whole lower arm. Some mechanics can change it I think. Ingat na lng sa mga taxi units..
