Originally Posted by
snoot
to those asking kung ok sa arangkada...yes hanep sa arangkada! akala mo maiiwan ka sa upuan
don't forget that this has a 128 horsepower with 260 torque and VGT ( variable geometry turbo )...yes naka TURBO po! kaya dapat marunong gumamit ;)
Does a turbo engine require a cool down period?
Answer:
Yes, a Turbo requires a cooling down time. How long a time really depends on how hard the car was driven prior to wanting to turn it off.
A turbo requires oil to circulate through it in order to keep it cool and lubricated. When you turn your engine off, the Turbo will continue to spin only oil will stop being supplied to the turbo unless the engine is running. THis can cause th turbo to heat up, and for residual oil still on the turbine blades to "cake" on to them. Over time, unless you allow a col down period, you will notice a substancial difference in the performance of your turbo.
Most car manufacturers will not even mention this to you when buying a car with a turbo, and if they do, they will generally recomend a cool down period of 10 seconds. I would suggest 30 seconds after regular driving, and 1 - 1 1/2 minutes after hard driving. from google
