Originally Posted by
bloowolf
I own an Accent hb so I know. Ok, we will go through this step by step. Be sure to secure the tire at the opposite side with a piece of wood.
1. Install the jack under the car at the specified jacking points
2. Loosen the lugnuts.
3. Jack the car up until you can rotate the wheel by hand
4. Remove the lugnuts and remove the cover
5. Replace the lugnuts and tighten alternately
6. Loosen the jack then tighten the lugnuts again in an alternating pattern
7. Repeat on the next wheel
*please also refer to your manual on how to change tires.
