Originally Posted by
markus
Started getting steady vibrations on my Starex 99 TCIC A/T on speeds of about 70Kph up. It is not an alignment/ wheel problem, the steering is steady as can be. It seems to come from the transmission, but the whole cabin vibrates. Even at neutral, at these speeds, the vibrations do not go away.
Any idea on what is causing this? There may be similar exeperiences from other Starex owner here, would appreciate if you can share how you fixed the problem. Would like to have an idea before heading over to the shop.
Thank you very much.
