Page 7 of 43 FirstFirst ... 3456789101117 ... LastLast
Results 121 to 140 of 3189
    May 2011
    My 1.6 Elantra after 1k PMS is holding onto the 7.8L/Km FC.
    Thats Every day driving from Marilao Bulacan to Ortigas then around makati and back to Marilao.
    Quote Originally Posted by mk73mhz View Post
    may hi way yan ata nlex, mine is 6 to 7 from valenzuela to makati but 3 to 5 stops before maati, dami ko dinadanan, and nasasa bay ako sa rush hour
    May 2011
    Quote Originally Posted by boybit View Post
    from my house in marilao to NLEX entry is 30 minutes with regular traffic. From NLEX to Balintawak is Hiway driving. Balintawak or Mindanao ave to ortigas is regular traffic.
    Stop for awhile then from ortigas to Makati and around then back to ortigas then in the afternoon uwian to marilao reverse byahe.
    Thats everyday - reached 1k odo in less than 2 weeks.
    hehe now at 7.9L/100km = 12.8km/L - always on eco drive
    1.6 Elantra - Silver.
    HTH
    Aug 2004
    HTH
    Just tested the Accent... 12.8 km/l indicated is actually closer to 11.5 on that particular car... maybe similar error for the Elantra, but that still puts you in the 11's... not bad if you have to drive through Ortigas and Makati every day.
    Aug 2004
    HTH
    Just tested the Accent 1.6... 12.8 km/l indicated is actually closer to 11.5 on that particular car... maybe similar error for the Elantra, but that still puts you in the 11's... not bad if you have to drive through Ortigas and Makati every day.
    Jul 2011
    Quote Originally Posted by tomatored View Post
    ouch! malakas pala sa gas ang elantra. pero feeling ko nga di accurate yung sa trip computer. kailangan pa magexperiment. thanks sa mga nagconvert ng km/100l to km/l.
    sa ford fiesta thread. they disconnected the negative terminal ng battery for 5 minutes, press the brake during that time, then reconnect terminal. nag improve fc and gear change ng at nila. baka pwede yan sa inyo.
    Jun 2011
    Quote Originally Posted by spymaker View Post
    what's the logic when doing this?
    Apr 2010
    hello,
    i am about to buy the 1.8L elantra. guys from hyundai say the fc ranges from 11 to 13 for city driving. is this true? what is the acceptable fc of an 1.8 sedan? thanks!
    Quote Originally Posted by Fredericko View Post
    may be they are pertaining in resetting the ecu, like hard reset. parang nag format ng computer gaganda ang performance. apllicable sya sa mga programming ng ecu na may bug pa
    Yup, that's resetting the ECU. That's sort of an instantaneous way of having the computer re-check its parameters. This is also done when you make some upgrades/mods. Instead of having the ECU 'learn' the new mods over time, you are putting it to sleep and slapping it awake right away.
    Jul 2010
    Has anyone tried this already? Any update?
    I travelled from Sto. Tomas to Vigan. Had full tank (sagad up to apaw) and when I arrived in Vigan, still had 3 bars left. Hataw mode pala to.
    In the monitor I had 7.6L/100Km ~ 13.15Km/L.
    While city driving here in Vigan, my FC is at 11.3L/100Km ~ 8.85Km/L
    Is this consumption normal?
    My Odo now is 860+, so nearing my 1st PMS. I plan to have it done in Hyundai Laoag, any elantra owners who have experience in Laoag?
    Cause I plan to use semi-synthetic oil.
    Appreciate your feedback. Thanks.
    Yes it's true. You can do that sa mga de-ECU. Sa Honda naman wala na kailangan gawin na iba just disconnect the negative pole.
    Sa Hyundai ganun din, disconnect the negative pole, 30 minutes is enough para sure na naka-reset ang ECU. Or pagawa niyo via GDS, better yun.
    Feb 2005
    was anyone able to make the inner tail lights work when the headlamps are on?
    Aug 2004
    Quote Originally Posted by Jackdripah View Post
    Sounds reasonable, i heard many people are changing to fully synthetic after its properly broken-in. around 10T km...
    sounds reasonable, accdg to US Govt. EPA measurements, the car can do 40mpg (hiway) so that's around 17km/li... pero since ang hiway naman sa atin ay madami dami din ang slowdown and re-acceleration. kaya siguro mas mababa. pero not bad na 'yan...
    tungkol naman sa oil, normally mga 10T km. sila nag papalit to semi-or fully synthetic oil.
    update sa color ng elantra kanina may naka display na dark blue sa hyundai shaw, 1.6 din
    1.6GL registered 12.8 km/liter on city/highway driving yesterday
    60% highway, 40% city
    route: Malate-Trece Martirez-Las Pinas
    max speed: 100 kph
    Sep 2008
    Pre-1K pms FC ko after my 3rd full tank (di ko nakuhanan yung unang dalawa), 1.8GLS A/T, Petron Blaze:
    360km/34.68li = 10.38 km/li
    70%highway, 30% city
    Lower than my expectation, I'm hoping it will improve as the engine gets broken in.
    Kakapalit ko pa lang ng semi-synth oil. after 5K siguro ako gagamit ng fully synth and hopefully gumanda na ang FC.
    Sep 2008
    Had my 1K pms yesterday at Hyundai Global City. Paid a total of P2057.00. Prompt naman ang service nila. Sablay lang sa akin yung sinabi ng SA na ang next PMS dapat is at 5K km or 3 months, whichever comes first at ganun na daw ang magiging succeeding interval. Ibig sabihin kelangan ko magpa-pms ng minimum of 4 times/year regardless kung ginagamit ko o hindi yung kotse ko.
    This is a rip-off IMO, considering 5 years mo ito gagawin to preserve the warranty.
    June 30
    1.6 GL Manual
    7.1 liters per 100 kms (14 km/l)
    95% highway, 5% city
    Bacoor to Malate (approx 25kms)
    Max speed: 80 kph
    hehe sorry... advance pala ng one month
2011 Hyundai Elantra [MERGED]
