Page 42 of 43 FirstFirst ... 32383940414243 LastLast
Results 821 to 840 of 3189
    not free......self install..........how many kms did you guys first change the spark plug???
    Posting for a friend.
    2012 Elantra A/T
    We observed his Car kanina. Yung idle kasi biglang drop to probably 500 then back t normal.
    Ramdam mo din yung nginig ng engine as the idle drop.
    Dinala sa Casa kinabit sa scanner normal naman daw lahat.
    Told him na only use 91 ron and not higher than that, hindi ba meet the minimum and you can opt to get the higher ron?
    Kutob naman namen baka bad fuel nakarga kaya ganun? Possible kaya?
    2012 Elantra A/T
    throttle body cleaned?
    if not..
    remove the negative on the battery. and remove the throttle body (10mm nut driver). *loosen the air ducts' clamps and the vacuum hose clamp to access the throttle body.
    if not..
    Thank you Sir. Will let him know.
    I forgot.. use throttle body cleaner or carb cleaner. medyo sensitive. first and last step ang ground ng battery. remove the throttle body from the engine. 4mounting bolts. one wiring connector.
    Sir Casa already cleaned daw the throttle body nung dinala niya prior posting the issue here
    napalitan na yun pcv? it could be cleaned(carb cleaner) and checked. remove the clamp(number 2 sa picture) and use a 22mm socket to remove the pcv. it should rattle(simple test). hand tight lng when putting it back.
    if its stuck open, no vacuum- might causes misfire then low idle.
    or it could be a clogged fuel filter-another reason for low idle.
    Will ask and let him know.
    Thanks again sir, highly appreciate it.
    mechanic-4-hire!
    only for today!
    facebook photos hosting
    jk😜
    Sep 2008
    mechanic-4-hire!
    only for today!
    jk[emoji12]
    Anong part po ito?
    starter brad. failed at 225,000km normal wear and tear item. 45minute job. konting baklas lng.
    lower arm overhaul...
    entire assembly replacement?
    or yung goma lang?
    just the bushings and balljoints.
    easy fix yun sa steering wheel. symptoms.meron clanking sound sa steering. sira kasi yun plastic part.
    hmm diesel na elantra? ive no idea meron pala nito sa pinas.
    Aug 2016
    Planning to buy elantra 1.8 2012 or civic fd 1.8 2009. Any recommendations and advise?
    Sent from my MHA-L29 using Tapatalk
    Quote Originally Posted by miguel20 View Post
    Hard to see by which metric the Elantra wins over the FD pag similar condition, except for 'rarity' on the road.
    FD, definitely.
    It's one of the classic Hondas, a class-leader in its time.
    Apr 2010
    FD, definitely.
    I had an FD for 5 years, It's just like any other car. Pag tumatanda, nasisira. Yung engine support lagi nasisira. Yung aux fan sobrang ingay. I like the Kia/Hyundai 6-speed AT better than the FD's 5 speed. Parang kapos FD sa overtaking. But when it comes to steering I like the hydraulic PS of FD better than MDPS of Hyundai/Kia (not artificial feedback), kaya lang nag leak din w/in 5 years of ownership.
    Mar 2019
    Hello noob car owner here and car is Elantra 2011 (1.8L AT variant).
    I had my car checked and according to the mechanic it needs to have the ff changed: Engine Oil, Automatic Transmission Fluid, Drive Belt and Spark Plugs.
    Question #1:
    - Ok po ba Aisin engine oil and ATF? Saw these in Lazada:
    5W-30 full synthetic oil https://bit.ly/2UVVzYa
    4L full synthetic ATF https://bit.ly/2CC2M8Z
    Question #2:
    - Any idea kung ano oil filter niya? Cartridge o element type? What size?
    Question #3:
    - Is it true that only 4L is required for ATF change? Manual says AT is 7.3L pero sabi ng mechanic 4L lang?
    Question #4:
    - San po kaya makakabili ng murang iridium spark plugs in Banawe?
    Thanks po sa sasagot!
2011 Hyundai Elantra [MERGED]
