me i use sea oil, malaks humatak, yun shell unleaded matakaw but smooth, best ive tried is xcs, matipid at smooth,
Will pick up a tomato red 1.8 GLS elantra on Sept 2. Will post pics of OEM GPS at work and full functionality.
Despite logging less than 400KM, Ella is very composed and the engine is relaxed at 100KMH, with RPM just around ~2000 when coasting at SLEX.
Step up slightly to 3000 RPM and the car easily reaches 140KMH. Upon reaching desired speed, steadily push back on the throttle and the car will coast around 1800-2000 RPM.
Just to clarify, the Elantra is far from perfect, but given the price of this econobox, it sure is a good buy . . . only problem is, my wife liked it so much, ayaw na niyang isoli huhuhu![]()
Nice! I also cruised at the same speed at SLEX but at about ~2krpm. That's the fastest i have tried with the elantra. Once I get past above the 5k mark, I'll try if I can floor further.
Btw, there's a forum started dedicated for elantra ph owners, just click on the link below:
ElantraPH
Agree ako diyan, although mabilis at matipid sa krudo si Navara, para ka pa ring nakasakay sa Jeepney na matagtag at parang may vibrator . . . tuwing bibiyahe from cavite to manila, para kaming pagod na pagod ... whereas sa Elantra, fresh na fresh pa hehehe
Pero naglalaway pa rin kami ng mga kaopisina ko sa VGT na Strada . . . naku nabangit mo pa ... drool . . .
:drive1:
Saw a white Elantra with license plates this week. I got my Elantra June 1, my agent called just 2 days ago to say that my license plate is already available
Well its true nga na nakaka interfere ang metallic tints sa radio reception. Pero sa printed antenna's case naman, nasa glass naman nakadikit yun and yung tint nasa ibabaw ng antenna. So malabo rin maka interfere sa reception, unless pina tint muna bago kabitan ng glass printed antenna, which is highly unlikely. Ang alam kong magkaka problema sa reception pag metallic tints ay gps reception. First hand experience ko ito, akala ko nagloloko na gps ko, pero nung nilipat ko sa isang car ko ayos naman pala. Naka 3m metallic full windshield kasi ako kaya ganun. Yung isang car ko neutral non metallic shade lang
I never had a problem with my GPS connection, radio signals, or cellphone signals due to my BC35 tint on the windshield ;)
My BC 20 sometimes gives my GPS a hard time finding the satellites. Moving while it does its sat searching also does not help. Hehehe!
Thanks sa input mga sir! Actually nag inquire ako sa balintawak branch, 10% per annum ang binigay sakin na interest rate pag inhouse, then pinipilit pa nung sc na 88k all in ang idown ko. Ayaw nyang icompute ung gusto kong down na 400k all in.
Then nirefer nya ako sa psbank, makakasave daw ako ng 200k. A day after ko mag fill up ng credit app form, tumawag psbank, 51% daw rate pag 5 yrs..walang pinagbago rate..tsktsk..try ko mga suggestions sa taas, thanks again!
sir, suggest you apply directly sa bank, you can haggle for a lower rate. Kasi, if im not mistaken, pag thru dealer, may patong na for their DI. BPI, PSB, BDO, choose the bank that offer the lowest rates, plus the free comprehensive insurance w/ AOG. Just my .02 cents though.
Thanks sir! i've found a sweet deal with BPI, hopefully maayos na lahat para by next week madeliver na ung unit.
