Page 8 of 23 FirstFirst ... 45678910111218 ... LastLast
Results 141 to 160 of 1208
    Oct 2004
    So far wala pa naman naka experience ng ganito,baka isolated case lang yung sayo
    Oct 2008
    yes, I believe he's the first to report that issue. try nyo sir magtawag sa ibang dealer na malapit sa inyo. baka me stock sila.
    Quote Originally Posted by bratski View Post
    Jan 2011
    Bago nga yan.
    Hopefully stocks are readily available next time...
    Mar 2011
    Mukhang very low ang clearance ng bottom natin. Kanina sa may konting incline ay may nag grind sa ilalim at may natanggal na rubber gasket cover of something. I have yet to find where it fell out of pag nai jack up ko na. Also the 3rd brake light ay prone to dust and insects getting in. Akala ko it's a sealed unit pero may nakita akong butiki (baby) and lots of mold like dirt inside. Doesn't help na humid dito satin. Sana di ma-void ang warranty ko pag binuksan ko ito..whew!
    And, it was a very tiring weekend kakaalis ng water damage sa body especially sa glass and mirrors. My fault not to immediately wipe the car dry after washing with our brand of "NAWASA". Our municipal water is crap! and if left to dry, it will actually etch your glass or mirror. That's how strong it is. The thing left so much hard-to-remove water damage and I learned a valuable lesson in the process to wipe the car dry immediately after washing. I don't care if it's Evian natural spring water from the Alps or irrigation water, it must be wiped dry! immediately.
    That is also crap to hear about a 2 month old car with a failing fan. I bet there are twenty plus year vehicles out there with nary a 'fan' problem.
    Jan 2011
    Quote Originally Posted by CooperS View Post
    I also bet that you have heard the word "isolated case"...hehehe joke lang sir.
    Lets wait if this failing fan is common to all, before we make final judgement.
    Oct 2004
    *boggsy
    The rear speakers are already mounted on the rear doors. So there is no point in adding provisions for 6x9's at the rear deck.Besides, if you opt to replace your stock speakers, you will only replace the fronts. Many audiophiles upgrade only their front speakers for better sound quality and imaging. The rears only act as fillers.
    Many cars dont have the auto up feature on the drivers side window, even cars costing twice or thrice more.
    Sep 2011
    Thanks guys. I guess your right. But for the central lock, it comes standard for the A/T, im just wondering why there are times it doesnt lock on its own when I start my engine and drive. I read on the manual, it has ignition-controlled door locks. Have you guys encountered this?
    Oct 2004
    Quote Originally Posted by Boggsy View Post
    It has an auto lock feature, but only when all doors are closed before you put the key in the ignition.after the engine starts, thats when it auto locks.it doesnt have a speed sensing doorlock though. For the doors to lock again, you have to switch off the ignition and then on again.
    Sep 2011
    Thanks sir.
    I think na figured out ko din, that you have to position the key to AC ON for 2-5 secs muna before turning it to ignition. Kasi pag straight ignition turn, there are chances na di sha nag lo-lock.
    Need advice lang po, may cash na po ako pang 50% to 60% downpayment sa 1.4AT, but with this issues being encountered in 2011 Accent, would you still advice me get it now? or maybe wait for a few more months na baka yung mga new units wala na nitong mga issues na ito? First car kasi, Tempting na ibili ko na lang ng 2nd hand Mazda 3 or Ford Focus Hatch or other cars na pasok sa budget.
    Oct 2004
    ^at mukhang matatagalan pa bago maayos.
    Jun 2011
    kamusta na po. yung nagpakabit nang o sulee sa accent nya? di ko na mahanap kung saan thread nang accent sya nag post kaya dito na lang ako nag post. hehe thanks in advance for your respond!
    Oct 2008
    So far so good. No bottom-out issue since it was installed. See pictures for reference
    Left shock
    Right Shock
    Quote Originally Posted by callmenadz View Post
    Jun 2011
    Quote Originally Posted by maxhedrum View Post
    Left shock
    Right Shock
    thanks for your info sir max! between kayo din po yung may knocking issue sa accent nag pa update po ba kayo nang ecu?
    Oct 2008
    yes meron din pero di ko talaga pansin kaya di muna ako magpapa-update.
    Oct 2004
    Ang alam ko taga paranaque yung nagpakabit ng o-sulee
    Jun 2011
    si sir maxhedrum po ata yun. em not sure also
    Oct 2004
    I think siya nga yun. Yung unit ko hindi naman ako naiirritate kahit very soft yung rear suspension. Ang nakakairrita yung knock. Kaya garahe muna si accent ko or probably once a week ko nalang muna gagamitin until ma solve ng hari ang issue
    hi guys!
    when kaya magiging available door sill protector? found out ang dali pala magasgas, more so sa rear passenger side.
    Nov 2004
    Hey guys, recently found this thread. But I bought the new Hyundai Accent months ago. I'm having problems with Fuel consumption and loss of power. Id rather use my gas fortuner than the accent in traffic.
    Now, it is in Hyundai E.Rodriguez for further road testing for the nth time, 3rd time actually, since they do believe that 7kms/L is efficient for city driving.
    I requested a highway test which they scheduled tomorrow. I will ask them to certify the results in paper. Hopefully, they could resolve the problems.
    I also asked what action they would do. And said they will still ask the technical manager.
2011 Hyundai Accent issues, problems in general
